 I need a Mixer View next topic
PostPosted: Thu Apr 05, 2012 7:58 pm Reply with quoteBack to top
Here's what i want.
Powered
12 Channels
(2) Monitor Mixes
On board effects
Mono Sub Out (for external sub)
So far I'm leaning towards the Carvin. Is anyone aware of aynthing else out there that is comparable?
PostPosted: Thu Apr 05, 2012 8:17 pm Reply with quoteBack to top
If I had to buy something with that spec, I would buy that carvin road warrior mixer.
PostPosted: Thu Apr 05, 2012 8:38 pm Reply with quoteBack to top
The only one I am seeing is the RX1200L, and then adding the Rack Case to it.
Is that the one you're looking at? Cause that's the one I'm looking at. There is an older one on E Bay, but that's pick up only.
PostPosted: Thu Apr 05, 2012 11:00 pm Reply with quoteBack to top
This one:
C1648P Powered 16 Channel Mixer
- 16 Channels
- 4 500W Power Amps (200W @ 4 Ohms)
- 6 Monitor Sends, 2 Effects Sends
- 4 Band Channel EQ w/ Dual Mid-Sweep Parametric
- 2 Digital Effects Processors
- 4 Bus Compressors
- 2 USB Power Ports
- Up to 2 Onboard USM Wireless Systems
$999
