 MXR 10-Band crackle and pops View next topic
dan_plus_o
PostPosted: Thu Nov 01, 2012 12:09 am Reply with quoteBack to top
Hey guys, I know a few of you here either have or had an MXR 10-band EQ before. I bought one because of the recommendations on here..
Today is a sad day Sad
Lately my MXR EQ has been making crackling and popping noises. I tried different cables, in front of the amp, and tried different wall outlets and it still makes the same noises. The only thing I have not tried, is a different power supply.
Just wondering if any of you have had this issue and do you think there is anything that can be done for the pedal? I did a google search and found at least two other cases where people were having the same problems.
Pedal is well out of warranty
I will see if I can get a new power adapter to try but I'm fearing the worst. Unfortunately, this pedal does not accept batteries.
Guitars: LTD V-401, Edwards Alexi Laiho Scythe, Simon & Patrick Songsmith
Pedals: Boss ML-2 Metal Core, MXR 10 Band EQ, ISP Decimator noise reduction
PostPosted: Thu Nov 01, 2012 12:36 am Reply with quoteBack to top
It may be out of warranty but they can and will still fix it for you dude. If you call them and get an RA # they will take care of you. It's probably a $10 fix.
PostPosted: Thu Nov 01, 2012 1:57 am Reply with quoteBack to top
Maybe try spraying the sliders with an electronics cleaner? Probably the level control, you might also want to check that the in/out jacks are still soldered correctly. A few minutes of your time may save you some money with an easy fix
dan_plus_o
PostPosted: Thu Nov 01, 2012 7:20 am Reply with quoteBack to top
That's a good idea. I did spray the crap out of it with compressed air.. I think I have some contact cleaner around my house somewhere.
I'll take a peek on the inside and maybe hit the solder joints up with a tad bit of solder. I did try putting some pressure on the cable jack with them plugged in and this didn't effect the sound so I don't think it would be bad solder joints on the in/outputs.
I did notice that if I turn everything up really loud and tap on the pedal really hard that the noise from me tapping actually comes through the speaker. I thought that was interesting.
I will try this as a last resort since I'm sure shipping from Canada will be a fair bit. My soldering iron is getting dusty too Laughing
PostPosted: Thu Nov 01, 2012 8:46 am Reply with quoteBack to top
Open her up
Plug in guitar and amp
Gently wiggle one wire at a time Wink
Also gently bend the tabs to hold the cables tighter Cool
PostPosted: Sun Nov 04, 2012 3:08 pm Reply with quoteBack to top
Always a good idea.
DOA# 9 02164
PostPosted: Mon Nov 05, 2012 2:44 am Reply with quoteBack to top
I'm having this same problem. If I turn down the Presence on my amp, it helps a little. But, i dont want to turn down the presence. I eq with a lot of high.
This maybe is a common problem?
Amptweaker, MXR, Boss, Digitech, Ernie Ball strings/pedals, Dunlop Wahs and picks.
dan_plus_o
PostPosted: Wed Nov 07, 2012 5:25 am Reply with quoteBack to top
I've tried everything suggested and still problems.
I still haven't tried a new power supply but am doubting that is the problem. I'll see if I can get a hold of a new one to try it out.
I have also tried the pedal with all the sliders cranked down and it still makes noise. The position of the sliders or EQ settings on my amp do not seem to affect the issue at all.
There is no noise when the pedal is in standby.
I guess I will contact MXR and see what they say.
PostPosted: Wed Nov 07, 2012 5:39 am Reply with quoteBack to top
Send it to MXR and you'll get it back good as new for a few bucks out of pocket.
dan_plus_o
PostPosted: Sun Nov 11, 2012 5:52 am Reply with quoteBack to top
Sounds like you have some experience dealing with MXR Lanning?
How much do you think it would cost to get it fixed in total (Shipping + shop fee)?
The only reason I am asking is because I actually have my entire setup for sale (amp and all pedals). I just got an email from someone who is interested in buying the whole setup. I am just wondering how much I should be taking off because of the pedal issues.
I was just about to send it off to MXR too but I don't want to make this guy wait for the pedal to get back because he might lose interest in my gear.
Oh and in case your wondering. I love the setup. I am selling due to University. I will have very little use for the stuff. I hope to get an ElevenRack or something I can easily move around and play with headphones.
PostPosted: Sun Nov 11, 2012 6:08 am Reply with quoteBack to top
Double post...
Last edited by Lanning is Killdozer on Sun Nov 11, 2012 6:13 am; edited 1 time in total
PostPosted: Sun Nov 11, 2012 6:09 am Reply with quoteBack to top
I'd say no more than $30.
dan_plus_o
PostPosted: Sun Nov 11, 2012 7:17 am Reply with quoteBack to top
Alrighty! Thanks for the info
dan_plus_o
PostPosted: Mon Nov 19, 2012 7:39 pm Reply with quoteBack to top
Hey I just got in contact with MXR.
They charge a flat rate of $75. I will also have to pay shipping one way.
So I'm looking at around $90 to get a $130 pedal fixed.
I think I'll hang it on my wall or something Laughing
Anyone want to buy a piece of s#%t MXR EQ pedal?
