 Presonus tube Pre V2 View next topic
PostPosted: Mon Jan 07, 2013 5:39 pm Reply with quoteBack to top
Has anybody tried this? I'm thinking about swapping my Art Preamp out for it. The 80Hz Rumble filter is very appealing to me since I seem to get a lot of that low rumble in my recordings.
http://www.presonus.com/products/TubePre-V2
PostPosted: Mon Jan 07, 2013 7:04 pm Reply with quoteBack to top
I have used the original and like it. I don't know about the V2 but I'm sure it will be as good or better.
PostPosted: Tue Jan 08, 2013 12:20 am Reply with quoteBack to top
I would recommend to quit trying to use tube preamps on your guitar. it will always dirty up. you want a clean solidstate preamp signal for micing guitars with digital. was different for tape. tube preamps usually work better for vocals only.
PostPosted: Tue Jan 08, 2013 12:21 am Reply with quoteBack to top
You can just get a cheap Behringer mixer. Those have preamps built in to each channel. Tube preamps, like Chris said, will distort easier and may not work for you. I have only ever used them on Vocals and bass guitar.
PostPosted: Tue Jan 08, 2013 12:47 am Reply with quoteBack to top
That's what I'll do. I tried again tonight and I'm almost ready to give up. I'm going to return the art and see what else I can find. I'll look into the solid state mixer thing.
I just hope the rig sounds better going through the PA than it does into Reaper right now. Shocked
It's like sex for the ears in the room... Laughing
PostPosted: Tue Jan 08, 2013 12:50 am Reply with quoteBack to top
Can you message me on FB and remind me what it is you're trying to do here? lol I'm a little lost at this point to give you help because I have lost sight of what you're doing Laughing
PostPosted: Tue Jan 08, 2013 1:14 am Reply with quoteBack to top
If I get this one I can run the emulated mic out in conjunction with the SM57 and mix them. I like the idea of having eq's right on the board for simplicity.
http://www.long-mcquade.com/products/258/Pro_Audio_Recording/Mixers/Behringer/Xenyx_8_Inputs_and_2_Bus_Mixer.htm
This one is nice too and a little rugged.
http://www.long-mcquade.com/products/6679/Pro_Audio_Recording/Mixers/Mackie/402-VLZ3_-_4_Channel_Compact_Mixer.htm
