Thu Jan 17, 2013 6:03 am |
So I just got a presonus audio box interface and its 24 bit.Now Ive been making my demos with sony music studio acid 8.0 on the drop down tab in the program it gives me 2 options for bit rate 8 and 16 so my question is can i still use the 2 together? will the interface do up to 24 bit?or only 24 bit?
please only reply if ur sure of your answere.thanks |
Thu Jan 17, 2013 3:15 pm |
wow nobody?
Thu Jan 17, 2013 3:21 pm |
| RobBouchardDeanml wrote: |
You made the rules Rob  |
Thu Jan 17, 2013 3:39 pm |
With my sonar program, it when you configure the two It will give you all of the options that you have available. So If you have a 24 bit interface, 24 would be the highest in the menu. I am not familiar with sonys software, but you should get more choices in your dropbox when you configure your setup. Thats how mine works, hopefully yours is the same. |
dogpound71
Thu Jan 24, 2013 1:30 pm |
It will only record in 8 or16 bit...which is the limit of the recording software...yes, you can use both together, but at 8 or 16 bit only. I like Sonar. |
dogpound71
Thu Jan 24, 2013 1:45 pm |
...or you could upgrade to Acid Pro which supports 24 bit...or even Acid Studio has it too I believe...edit: I think Acid Studio 7 did 24 bit and they lowered it in 8... I will check into that. |
