Wed Feb 06, 2013 12:55 am |
Do Dean guitars have double action truss rods? I just adjusted the neck on my CFH and it felt like it was tight both ways, not the usual tighten to the right and just go slack to the left.
I had no problems adjusting it, I just thought that was kinda cool. |
_________________ 04-00403
Good deals with: Metal Mike,Metalwolf427,Helltone,Unklebill,what-a-cool-username,rridner,'87 sherwood,Bloodroot,hellboundinFTworthTX,unscarred666,Frogman,jdwon1172,Halfaed,Panterica83,RC99,Catbox brown.....and a lot more |
Wed Feb 06, 2013 1:32 am |
Yep. Most all the allen wrench type rods are 2 way. Turning to the right will pull the neck back, to the left will push it forward. Of course there will be a point in between where it is completely loose in the neck. I had a 79 ML that the neck played perfect with the rod completely loose with no tension either way, just kept it slightly snug to hold the neck straight. |
_________________ Randall Century 200
Rg80ES-XP
Ceriatone Chupacabra
JCM 800 |
