 Just had an epiphany about action View next topic
PostPosted: Tue Mar 12, 2013 2:23 am Reply with quoteBack to top
When I change my strings I usually always check my action and was thinking about the easy way to measure a medium low action. BAM it hit me!!! A penny for the treble side and a nickel for the bass side, each measured at the 12th fret. It's almost exactly how I like my strings and much more readily available than a ruler or calipers at a gig in poor lighting.
How do you measure your action? Or do you even care?
PostPosted: Tue Mar 12, 2013 2:29 am Reply with quoteBack to top
if you do it right and youre just changing the same guage as last time there is no reason to check or change your action.
PostPosted: Tue Mar 12, 2013 2:31 am Reply with quoteBack to top
With all the humidity and temperature changes here in MN, I check this with every string change. Adjustments typically need to be made twice a year.
And funny, I thought I've been doing it right all these years. Shows how much I know.
PostPosted: Tue Mar 12, 2013 2:32 am Reply with quoteBack to top
your action changes when the neck moves also. weather /time
Mesa mark 4
Framus Dragon
Triamp mk2
Engl Savage 120
Framus Cobra
Mesa Triple rec
Randall RG100es
Marshall 2203kk jcm800
Engl fireball 100
PostPosted: Tue Mar 12, 2013 2:34 am Reply with quoteBack to top
I understand that but if you change them one string at a time with the same exact guage there is no reason to adjust anything. it was adjusted before you started.
PostPosted: Tue Mar 12, 2013 2:35 am Reply with quoteBack to top
It's terrible how much necks move around here. My main acoustic has been fighting me all winter because its so dry in my house. Have hardly touched it since my New Years gig.
Usually as long as the strings don't buzz I'm good to go. Prefer the action a bit on the high side.
PostPosted: Tue Mar 12, 2013 2:41 am Reply with quoteBack to top
I just set mine low enough that it doesn't buzz, never really worried about it that much. I'm different from alot of players in that I don't worry about the mechanics so much as long as it works for me.
I've heard stories about dudes obsessing over the types of screws used on a guitar and the amount of torque applied when tightening them. That is so not me. If it works, I'm happy.
Black/Gold ML
PostPosted: Tue Mar 12, 2013 2:50 am Reply with quoteBack to top
Bill Lawrence method from long ago. Nickel on treble side, two nickels on the bass side then I lower the bass side a little more
PostPosted: Tue Mar 12, 2013 2:51 am Reply with quoteBack to top
Damn dude that's $0.09 more than Lannings method Shocked
PostPosted: Tue Mar 12, 2013 2:53 am Reply with quoteBack to top
I am a big spender Brian Laughing
PostPosted: Tue Mar 12, 2013 2:56 am Reply with quoteBack to top
Couldn't you just use a dime?
PostPosted: Tue Mar 12, 2013 3:03 am Reply with quoteBack to top
That's it!!! I'm switching to Susan B Anthony dollars. Laughing
PostPosted: Tue Mar 12, 2013 3:06 am Reply with quoteBack to top
I set my action on the high side .. I pic very hard for some reason . Heavy handed . I even have to put extra relief in the neck . Guess im a weirdo .
Mesa mark 4
Framus Dragon
Triamp mk2
Engl Savage 120
Framus Cobra
Mesa Triple rec
Randall RG100es
Engl fireball 100
boombazilla
PostPosted: Tue Mar 12, 2013 7:32 pm Reply with quoteBack to top
Put it on your rider, it should make for some interesting glances, lol.
...2 cases of bottled water, 1000 red M&Ms, 6c US currency in newly minted untarnished, unworn coins (preferably 2010 issue).
PostPosted: Tue Mar 12, 2013 7:43 pm Reply with quoteBack to top
LOL Laughing
Bryan
PostPosted: Tue Mar 12, 2013 9:29 pm Reply with quoteBack to top
IIRC that's the method he uses for setting pickup height, not String height.
DOA 10-02348
I would imagine that a working band that draws a good crowd (200 - 500) though the door should be able to command a flat fee of one million spacebucks.
PostPosted: Tue Mar 12, 2013 10:07 pm Reply with quoteBack to top
I hand check them using the width of teh strings as a guage [usually the strings I just took off]. IF you know the number you're looking for this sis slihgtly more precise... maybe? its worked for me. just a thought.
I usaully only have to adjust my action/truss rod once in spring adn once in fall. others wise its a rock and doesn't move. I've owned a few guitars that seemed to move daily - what a pain in teh ass - I got rid of them just for that reason.
PostPosted: Wed Mar 13, 2013 1:26 am Reply with quoteBack to top
I have the patented Stew Mac string action guage. it works well. Otherwise I use a pick. Smile
PostPosted: Wed Mar 13, 2013 1:46 am Reply with quoteBack to top
Little steel ruler.
And these days, glasses....
DOA# 9 02164
PostPosted: Wed Mar 13, 2013 3:48 am Reply with quoteBack to top
Yep, you are correct but I do the same thing on the fretboard for good results at the 12th fret
JohnC
PostPosted: Wed Mar 13, 2013 7:08 am Reply with quoteBack to top
I usually just fiddle with it for an hour or so until it feels right. I never buy the same strings twice in a row so it's constant experimenting. I generally like my action fairly high though.
Rlee
PostPosted: Sat Mar 16, 2013 3:24 pm Reply with quoteBack to top
I have been using a slide gauge at the 17th fret 5/64 and 3/64th but I got a notched dig caliper I am going to start using. The coin thing has been used by a lot of people through the years its also very consistent to measure with.
Electrics I measure at the 17th , acoustics at the 12th because of fall off on frets jobs below the 13th
Carvin CT4
Epi Elite les pual (japan)
Blackstar series one 50
Carvin X212B
barcus berry xl20
roland cube
Line 6 m13
CMATMODS pedals
PostPosted: Sat Mar 16, 2013 3:56 pm Reply with quoteBack to top
Great idea Lann, thanks for posting!
I usually fiddle with it.., i'm sure a nickel on the treble side and nickel and dime on the bass would work for me!
