Sinker
Mon Dec 15, 2003 10:11 am |
I've played acoustic for years, but my EVO FT is my first electric. It seemed like the best bang for the buck in the price range: Grover tuners, set neck, plus it 'felt right' for whatever that's worth. Anyway, I know squat about pickups, and was just wondering if somebody could tell me something about the Zebras in my EVO.
I'm currently playing through a Roland Cube 30. The various tones available from the distortion models are overwhelming, I''ll play with them later. Right now I'm concentrating on trying to maximize a warm, clean tone with just a hint of delay and chorus. I know I'm asking a lot from a Korean-made guitar and a cheap SS amp, but believe me, I'm having a blast and am kicking myself for not diving in earlier. I'm also making some tones I really like (limited experience, you know).
I guess my questions are: 1) With my current set-up, would I notice a big improvement in tone if I were to upgrade the pickups?
Coil Tap? I know what it's supposed to do, but it sounds like crap when I switch to the 'single coil' mode.
Pickup selector. I assume down is bridge, up is neck and middle is both. I'm currently using mostly the middle position because I can't decide which I like best and for what purposes.
I'm not asking much, am I?
Go ahead, talk to me. Or send me to the appropriate resources.
Thanks in advance. |
_________________ ________
'02 Dean EVO FT (Black, of course)
'83 Peavey Foundation Bass
'81 Yamaha FG335E Acoustic/Electric
'77 Bach Strad Model 43 Bb Trumpet |
Justnoldbluzman
Mon Dec 15, 2003 10:19 am |
The Deans are wired out of phase so when you are in the middle position and you roll back on the volume a little from full you get a slight "flangy" sound. The coil tap really only eliminates the "hum" associated with humbuckers at a high volume, giving you a "crisper' sound, although somewhat thin. You are correct in the switch positions.
I personally haven't played an Evo so these observations are based on the setup on my Cadillacs and Elites, that I own. The best thing to do is to continue to experiment.
A good combination of pickups that I have used are DiMarzio Tone Zone in the bridge and DiMarzio BluesBucker in the neck.
Bill |
Mon Dec 15, 2003 10:25 am |
I think you'll notice a big improvement when replacing em with some high end PU's like DiMarzio's! |
_________________ http://www.myspace.com/thrashcorefanatics
DEAN ML flame BB 1981 |
Sinker
Mon Dec 15, 2003 10:44 am |
Speaking of Zebra Pickups
Ranma
Location: DOA 03-00174-ML 79 Black, ML NoirX-Fort Dix, NJ
Mon Dec 15, 2003 12:26 pm |
The Wind
Mon Dec 15, 2003 12:31 pm |
Docter M
Mon Dec 15, 2003 1:11 pm |
i usually hear that the zebra's are wound pretty hot, which i dont immagine is very good for the clean tone. put a Seymour Duncan Jazz in the neck. that'd probably be the best thing for what you want. |
_________________ DOA #03-0189
04 Dean DOA V Bass #12
03 Dean Edge Q6
73 Fender Jazz Bass
02 Frankensquier Dual P-bass
04 Fender Standard Fat Strat
04 Epiphone AJ-200S
04 Carvin R1000 Head
04 Avatar B212 |
Jeepocaster
Mon Dec 15, 2003 9:01 pm |
| Hotrat wrote: |
| Justnoldbluzman wrote: |
Bill |
I always thought that humbuckers were created to eliminate the noise that you got on single coils at high volume. hence the term "humbuckers" |
Yeah, they were... Thus the dual coils. No hum, as in 60 hertz cycle hum intrinsic to single coils. The coil tap eliminates one of the coils 'making' it a single coil . Back to the point, I recently installed a DiMarzio super distortion in the bridge of my eVo special with a tone zone in the neck. The tone zone will be moving, as it duzn't work well in the neck position but the super d izz staying. Really woke this little axe up! I wanna put a PAF in the neck, I think... We'll see... For what it's worth, I have been a long time seymour duncan advocate, and I put these old dimarzios in this guitar, and I'm happy. |
Mon Dec 15, 2003 10:00 pm |
AFAIK, none of the eVos are wired out of phase. Pulling up on the volume splits the neck pickup while pulling up on the tone splits the bridge. When a humbucker is "split" it means only one of the coils is being used and thus it is a single coil and not hum canceling. Hum canceling refers to EMI and RFI that the coils pick up. By reverse winding one of the coils, any EFI or RFI both coils pick up would be 180 degrees out of phase and cancel out. I'm not sure, but I think the fatter sound of humbuckers comes from having a wider magnetic field picking up the vibrating strings. |
Truthsayer
Mon Dec 15, 2003 10:06 pm |
If you like nice warm clean tones but still wanna rock, you can't go wrong with DiMarzio PAF-Pros in both the neck and the bridge.
A DiMarzio Super Distortion in the Bridge would be a nice choice too since you can get fat distortion in full humbucker mode and a nice clean tone in coil split mode. I have a PAF-Pro and a Super Distortion on order right now for my Dean Cadillac Select.
Visit the DiMarzio website for more information and MP3 samples of the pups in action. |
Hardrocker
Mon Dec 15, 2003 10:11 pm |
So , what do you think....Damarzio or seymour Duncan? I am thinking of replacing the pickups in a New Caddy. Any suggesstions on type of pickup , there seems to be so many choices.... I play in a local band, classic to new rock and like the Les Paul tone..Thanks |
_________________ DOE member -03-00237
Hardrocker |
Grumpy Goat
Mon Dec 15, 2003 10:58 pm |
| Hardrocker wrote: |
Welcome to my world. SD Custom custom should do it. That's my fave LP bridge pup. Dimarzio Super Dists are good too tho. It's just that for my taste the LP needs a bit of a fatter sound that the Custom custom produces effortlessly. That's my 2c anyways. |
MKK #9
papersoul
Sat Dec 20, 2003 4:06 pm |
I personally don't like the Zebras and have replaced them with Duncans and Rios.....I found them too tame and muddy. |
ragnut
Sat Dec 20, 2003 6:51 pm |
I hear many referring to "zebras" as a type of pickup. It's just a color pattern. You can get that zebra color scheme on a lot of different pups from different companies. |
Sat Dec 20, 2003 7:41 pm |
I know the Dean zebras in my V, Z, & ML Selects were very good pups, but the newer models don't seem as gutsy. I'd go with a good aftermarket pickup set. However the neck pickup in my Evo Special is nice like a PAF. Check the "golden age" humbuckers available from Stew Mac http://www.stewmac.com Price is right - |
DOA member #0200106 |
