 How loud is 75-watts (solid state) View next topic
Nick M.
PostPosted: Mon Dec 22, 2003 7:03 pm Reply with quoteBack to top
hey all,
i don't have enough money for the 100w randall, oh well, i'm happy with a 75w amp, but... how loud is it? is it loud enough to play a school gym? loud enough to make my ears ring if i play it in my bed room?
thanks
nick
ps: the model is called RG75 (at least i think it is...)
PostPosted: Mon Dec 22, 2003 7:16 pm Reply with quoteBack to top
Watt consumption is not a measurement of volume. It can be uesed as a relative measurement, for example, two class b power amps, one 30 watts and one 50 watts, it is generally safe to assume teh 50 watt will be louder.
I think you will find 75 watts is loud enough for any small to medium sized club with a decent PA. It will be PLENTY loud enough for your bedroom, and will not quite be loud enough for a school gym.
Question; Combo or half stack? Call em nuts, but I've always felt you got a better sound and more "ompf" out of a half stack... So a 75 watt combo amp will be swallowed in a gym, unless you're the only one playing. All in all, I'd say it probably big enough for everything you could need it for unntill you're playing 500 seat establishments. HTH!
Custom Dean "ankh" ML
Nick M.
PostPosted: Mon Dec 22, 2003 7:19 pm Reply with quoteBack to top
it's a 1x12" combo. i'm hoping it will be loud enough for a school gym, but hooking up the amp with mics wouldnt be a problem.
thanks joe!
PostPosted: Mon Dec 22, 2003 7:27 pm Reply with quoteBack to top
If they will let you mic it and are running it through a PA in a full abnd situation, You're all set. If you're talking about pulling a Doc Ozz Solo Star spangled banner, since you're the only one playing, it'll be fine as is.
Best of luck!
rustyguitar
PostPosted: Mon Dec 22, 2003 8:05 pm Reply with quoteBack to top
i play out of 75 watts and its loud enough for anything usually
Rex Herring
PostPosted: Mon Dec 22, 2003 9:03 pm Reply with quoteBack to top
I've played the Randall RG75 and it's plenty loud. It'll depaend on amount of people in the gym plus how loud the rest of the group is. It does have a speaker extension out on it so you can add an extra cabinet to increase the volume and cover more area. It'll push a 4X12 cabinet just fine but I have a single 12 cabinet that works for anything I've done plus there is a line out to run into a PA board.
DOA# 02-0015
DOA Caddy #17
"V-WING" #17
Razor NT-5
DOA Hardtail Bass #6
Both Sledge Hammer 5 Strings
Dean Edge Q-6 Flame Top
Dean Edge 1 - 5 String
Dean Rhapsody 4
throbgod13
PostPosted: Mon Dec 22, 2003 9:19 pm Reply with quoteBack to top
depends on the efficiency of the speakers and the cab..
if you use a single 12", in a sealed box, and the efficiency of the speaker is 88dB 1W/1Metre, then with 1 watt input, you should produce 88dB.. it's all logarithymic.. to get a 3.33dB increase in output, you'd have to tenfold the power..
blah, blah, blah...
read this.. it's about "audiofile" speakers, but the basic info is sound..
http://www.lansingheritage.org/html/jbl/reference/technical/efficiency.htm
DOA #01-0019
03 Demonator
guitarforceone
PostPosted: Mon Dec 22, 2003 9:39 pm Reply with quoteBack to top
If you're going to play in a gym, you are in for nightmare acoustics. There will be so much reverb you'll get lost in the slop.
Dana <~~~
DOA #02-00111
'82 Baby Z Pinkburst
'9? Icons Amberburst (3)
'85 Jackson RR Custom
'86 Jackson San Dimas Str*t
'86 Charvel Model 4's (6)
'87 Charvel Model 6
'90 Charvel 650
'05 Charvel San Dimas
Marshall heads (7) etc.
Nick M.
PostPosted: Mon Dec 22, 2003 9:40 pm Reply with quoteBack to top
Very cool! I'm not sure which amp i'll get, I'm very tempted to get the 100w 2x12" combo! I took out $600 in cash today to buy the amp, and my parents dont know. they're going to be really really really really really really really really pissed off when i come home with it on boxing day!!!
Pulse Of The Night
PostPosted: Wed Dec 24, 2003 6:27 am Reply with quoteBack to top
Volume isn't nessesarily measured in watts or even ohms for that matter. One large factor in volume is the amount of speakers you're useing.
Say you have a 75w amp with one speaker and a 100w amp of the same brand with one speaker of the same size as the other ( or any other brand for that matter) and you have the preamp set identicle. You wouldn't notice much of a volume differance.
Now, lets say that you have a 75m amp with two speakers and a 100w amp with just one. The rigs are set the same. The 75w rig with two speakers would sound louder then the 100w rig with one speaker.
Hope that helps
If you love someone, set them free. If they come back, place several 8 inch blades through their head. If they return again, run...just run.
mr_ed
PostPosted: Wed Dec 24, 2003 7:51 am Reply with quoteBack to top
IT'S THIS LOUD!!
Nick M.
PostPosted: Wed Dec 24, 2003 7:42 pm Reply with quoteBack to top
Hope that helps
yeah that's what i was thinking! i guess the 2x12" moves more air i guess..
we'll see if the guy at the guitar store will sell the amp for $600 no tax!
hsech
PostPosted: Fri Dec 26, 2003 1:23 am Reply with quoteBack to top
Loudest small amp I've ever played through was a Peavy LA 400. 210 watts through a single 12" Black Widow. Did a lot of outdoor gigs with it and never had problems under any circumstance. Now I have a Fender Stage 100 DSP that has a single Celestion and it IMO is loud enough for anywhere. You can add an extension cab to it with a single 12" Celestion and that brings it up to 160 watts at 4 ohms which is more than overkill for anthing I play. Keeping in mind that I'm 55 and playing that loud in a band just isn't my thing any more. I'm playing for older audiences now and no matter what the amp is set on it's always "turn it down". Razz
2004 Fender 50th Anniv Deluxe Strat
2002 Gibson ES-135LE
2006 Fender 60th Anniv Std Strat
2006 Schecter Stiletto Elite Bass
Mesa Boogie Studio Caliber DC-2
Mesa Boogie WalkAbout Scout Bass Amp
DOA# 03-00197
Nick M.
PostPosted: Fri Dec 26, 2003 1:28 am Reply with quoteBack to top
Well tommorow I'm off to the guitar store to buy my amp, which ever one it is, you can bet it will be LOUD!
Grumpy Goat
PostPosted: Fri Dec 26, 2003 4:00 am Reply with quoteBack to top
Wicked. Don't be put off by those who belive you have to have high nos of watts to get a big sound. My amp head is only 50w and it crushes our Rhythm guitarists 120w. Just play em and find the right one.
MKK #9
DizzyDean
PostPosted: Fri Dec 26, 2003 12:13 pm Reply with quoteBack to top
Watts doesn't mean a whole heck of a lot volume wise. My 50 Watt Hiwatt 1/2 stack will blow just about any combo out of the water volume wise.
Go to the store and turn it UP UP UP - the sales guys will love you.
Or - ask for the amp that goes to 11!!!
DOA 02-00007
