ragnut
Sun Dec 14, 2003 9:29 am |
Anyone have suggestions for a low wattage (8W or less) tube amp? I just can't seem to be satisfied with the gain tone I'm hearing from pedals or preamps. I'd like to be able to crank a low watt power tube at home without going deaf. I know there's a lot of kits out there, but I'd prefer one that's already built into a combo. |
liipotin
Sun Dec 14, 2003 9:42 am |
Hmm, if I remember right, Orange does have few low wattage combos. www.orange-amps.com
If you can go only with headm, check out http://zvexamps.com/ and click on the Nano Head. It's a ½ watt and really small. I'm thinking of getting one my self. I've heard a few clips of it and it sound's very nice.
Mikko |
_________________ DOA # 03-00234
Dean Custom ML Transblack
Splawn QuickRod
ENGL Vintage 4x12 cab |
Sun Dec 14, 2003 9:49 am |
you need to get hold of a thing called a "lil' smokey". They are 1 watt, sound great SS amp, and they can actually power a 4 * 12 cab! They are quite the neat little amp! |
_________________ Custom Dean "ankh" ML
liipotin
Sun Dec 14, 2003 10:34 am |
Oh, I almost forgat, Bad Cat Mini Cat 5w combo all tube amp. Very very nice. Little pricey though, but nice amp.
http://www.badcatamps.com/home.asp
Mikko |
Splawn QuickRod
Sprinter
Sun Dec 14, 2003 10:54 am |
I like to play through cranked Fender Champs. The Champ has 6 watts, and can still get fairly loud. There are lots of modifications that can be done to Champs. 70's silver face Champs can still be bought at reasonable prices.
Sprinter (The Champ Junky) |
ragnut
Sun Dec 14, 2003 12:11 pm |
Talan
Sun Dec 14, 2003 12:25 pm |
throbgod13
Sun Dec 14, 2003 12:59 pm |
i've played through a Matchless Lightning..
incredibly sweet.. 15w combo, i think it's an 8" speaker.. might be 10".. class A..
it's so sweet, the tone is like honey.. i've played a few guitars though it, and the general tone is very sweet.. there's nothing that sounds like an AC-15 in this Matchless..
it's nice for a high-end low-watt combo.. the one that i played through was $1699.99 at Rockin Robin in Houston.. (it's one of the older production Matchless amps)
for low buck costs..
the new Marshall Microstack MG15MS is really alot of fun.. 15 Watts, two little 10" cabs.. it's just fun to play through.. lots of SS gain.. but, it does have a decent clean tone to it, too.. |
_________________ DOA #01-0019
03 Demonator |
Bernt
Sun Dec 14, 2003 4:45 pm |
I'd say Fender Pro Jr. 10W tube |
_________________ DOA Caddy Bass #7 stolen
DOA V Bass #7 stolen
Dean Edge 6 stolen
DEAN E'lite 1980
DOA # 03 00163 |
Rex Herring
Sun Dec 14, 2003 11:10 pm |
If yu're just looking for a cheap tube practice amp, try one of these.
http://www.musicyo.com/product_specs.asp?pf_id=300
Also Kustom makes a small tube amp that Dave at B&T could help you with. |
_________________ DOA# 02-0015
DOA Caddy #17
"V-WING" #17
Razor NT-5
DOA Hardtail Bass #6
Both Sledge Hammer 5 Strings
Dean Edge Q-6 Flame Top
Dean Edge 1 - 5 String
Dean Rhapsody 4 |
sekler
Sun Dec 14, 2003 11:43 pm |
| liipotin wrote: |
Mikko |
yeah, a nano amp with a 4x12 !! I heard nice feedback about these |
Mon Dec 15, 2003 8:30 am |
Joe,
Hard to find exactly what you want in a small amp. I know, I've been looking for a while. The Class Act might be a viable solution for you.
RockinB |
Mon Dec 15, 2003 8:57 am |
Joe,
Some of the new higher wattage amps have a "power cut" so that you don't blow the neighbors away... plus it really gets to that sweet spot!
Additionally, THD's hotplate will do the same thing to higher powered amps. Steer clear of Marshall's Powerbrake.
I've used a HotPlate on my 55 watt twin Rivera yielding excellent results.
Chuck |
BobtheNuke
Mon Dec 15, 2003 9:21 am |
I'm with Sprinter in his suggestion for a low power amp. I don't have a Champ anymore, but it fits the bill for your requirements. Tube sound and overdrive and you'll never lose a penny on one of these. Silverface pieces can be had in the $200 range all day long.
~bob, the "vintage Fender amp" guy. |
ragnut
Mon Dec 15, 2003 9:45 am |
Would a power cut / power attenuator of a high wattage amp have the same effect as lowering the volume via the guitar knob, and/or decreasing the dB on an EQ pedal? Do you lose something in tone if this is done? |
BobtheNuke
Mon Dec 15, 2003 10:59 am |
Generally speaking, each and every audio device will have a "sweet spot" in tone and volume. For example, I have a couple of vintage amps that develop their best tone (IMO) between "5" and "6" with the guitar volume dimed. This will vary on the guitar and amp and is, of course, all subjective. Due to Fletcher Munson effect, lowered volumes will give the perception of less bass and treble and will require some EQ adjustments to maintain some "punch".
A "volume" box can be added to the effects loop (if your amp has one) which will allow you to overdrive the preamp section to develop some "growl" at lower volumes, but even so the tone can be compromised somewhat.
~bob |
guitardave
Mon Dec 15, 2003 12:30 pm |
Have you heard the cornford 6 watt harlequin. All hand made out of England. These guys even make their own transformers. Great tone at low volume. It's an A class EL84 amp. You should try one. |
Mon Dec 15, 2003 4:10 pm |
| BobtheNuke wrote: |
~bob |
Hey Bob! Nice to hear from you! ...as always... very informative.
Chuck |
Randall
Mon Dec 15, 2003 5:45 pm |
I got a blackface vibrochamp (silverface has the exact same circuit) for practice and think it is a great choice for a practice amp. It gets plenty loud, with a nice dirty growl running my Deans through it. I highly recommend it.
Randall |
ragnut
Mon Dec 15, 2003 6:03 pm |
| BobtheNuke wrote: |
...Due to Fletcher Munson effect, lowered volumes will give the perception of less bass and treble and will require some EQ adjustments to maintain some "punch". ..
~bob |
Ooooh, I had to look that one up:
http://www.webervst.com/fm.htm |
ragnut
Sat Jan 10, 2004 12:12 pm |
As a followup, I bought a 70's vibrochamp and have enjoyed it. I've read a lot about replacement speakers and different tubes that I decided to delve in. Here's my impressions of what I've tried so far, in case any of you are wanting to get a Champ, or care to offer me more suggestions.
I first changed the speaker to a ceramic 8" Weber. Result: no appreciable difference, which was disappointing but it was a fun first experience to switch out a speaker and it was only $24.
The amp has it's original Fender power tube; a 6V6GT that I'm not sure who made (RCA? Philips?). First one I switched to was a Brimar. Result: gong! Harder to overdrive and not as rich a sound. Next, Mazda. Result: thumbs down. Not as sweet and it was noisy. Next, RCA grayplate. Result: ding ding, we have a winner. About the same sweet overdrive as my original but less noise. This makes me think that my original in an RCA too -- they do look the same.
Switched the R3Y rectifier to a Mazda. Result: no difference, but it's supposed to help the tubes last longer.
Next was switching the original Fender 12AX7 tube to a $10 Ei. Result: suprisingly sweet! richer overdrive. Dollar for dollar the best change I made.
I'm planning to sell the original speaker and Brimar and Mazda power tubes if anyone is interested. I bought the tubes from KOS NOS tubes (Mike) who was very helpful. |
http://www.deanguitars.com/userpics/lib/7600034serial.JPG |
