z dogg
Thu Dec 18, 2003 6:27 pm |
Got my Z today. Of course Dave's sealed it up good in a shipping box which has a "don't open for 24 hrs". Well, I took it out of the box but have not opened the case. To tell you the truth, the case feels the same as the guitars under my bed. Should I:
1. leave it alone until tomorrow.
2. give it a couple of hours and open the latched to slowly vent the axe.
3. go crazy (sorry, already there)
thanks,
Jack |
Justnoldbluzman
Thu Dec 18, 2003 6:30 pm |
Jack,
DO NOT open the case let everything get acclimated temp wise, just because the outside of the case may feel room tempp the guitar itself isn't. Let it sit.
Bill |
z dogg
Thu Dec 18, 2003 6:39 pm |
Thanks Bill. I'll be patient. |
Justnoldbluzman
Thu Dec 18, 2003 6:48 pm |
Believe me I know how you feel I have a Ben Chafin prototype Ember arriving tomorrow and I want to open it right up. But it is coming from maryland and I am on the NH border.
Bill |
z dogg
Thu Dec 18, 2003 6:53 pm |
Man Bill, that guitar sounds really nice. I'm sure it's worth the wait. |
Thu Dec 18, 2003 7:02 pm |
Pictures! We need photo images!! You must be chewing your nails not to open it. |
_________________ DOA#03-00235
z dogg
Thu Dec 18, 2003 7:05 pm |
Yeah, I'm staring at the case trying to get through it. The actual guitar is on my avatar, that will have to do until I can get a digital camera! |
Thu Dec 18, 2003 7:29 pm |
AHHH!! Looks great! Who is the character holding it? Some how I picture Arnold's voice emmiting from him....We are going to pump you up with Da Volume of Da Metal!!!!!! YA!
z dogg
Thu Dec 18, 2003 7:42 pm |
Hey you know that guy, he saved the universe and had a crush on his sister! I just can't recall his name right now, but I do know he used to be in 2 Live Crew! |
Thu Dec 18, 2003 7:59 pm |
I feel the Force!
In a side note did you know Mark Hammill does the voice of The Joker for Batman animated shows. |
Thu Dec 18, 2003 8:10 pm |
Yes, isn't that wild. The first time I heard him use that voice was on The Flash tv show, i think he played this guy called the Trickster. Mark also narrates documentaries shown on the discovery channel and the like. Hey, it's a check!  |
z dogg
Thu Dec 18, 2003 8:11 pm |
CliffBurton1986
Thu Dec 18, 2003 8:16 pm |
| BTMN wrote: |
"Now itz time for some of dis "Meetalliiiica" stuff"
_________________ DOA # 03-0192
'01 Dean Edge 1 4 Str TAB
'02 Dean Edge Q5 5 Str QR
'07 DOA HT 5 Str #8
'03 MK Firefly 5 Str QB
'92 GK 800RB
'02 Bag End Q10X-D 4x10 cab
'03 Zoom 607
'04 MXR M-80
R.I.P. Condemned Already '03-'06 |
z dogg
Thu Dec 18, 2003 8:26 pm |
| 60srocker wrote: |
| Open the damn thing! It won't hurt a thing. 24 hours is absurd. |
Oh man, don't tempt me!!!!!!!!!! Believe me, there is an internal struggle.  |
z dogg
Thu Dec 18, 2003 8:45 pm |
| CliffBurton1986 wrote: |
| BTMN wrote: |
Your right CB86, For Whom the Bell Tolls would sound good right about now! |
zero_cool
Thu Dec 18, 2003 8:46 pm |
I'm no expert in guitars, but I see no reason why you can't open it. Temperature might affect it slightly, but I would think that mainly it would be humidity. I mean, it's just made of wood, the same woods that a sh*t-ton of other products are made of. I just wouldn't tweak anything on it until it "settles in". |
Thu Dec 18, 2003 8:59 pm |
The worry here isn't about the wood, it's about the finish. I don't know about the poly finishes, but nitro will crack like crazy if you open the case before the guitar has warmed up. |
keyedup2
Thu Dec 18, 2003 9:02 pm |
That's like being told "don't drive a new car hard until the break in period is over"..
I never Broke in a car....
That didn't come out right. Maybe you better let it sit(right next to your bed tonight). |
z dogg
Thu Dec 18, 2003 9:06 pm |
I hear ya! But I guess I'll hold off. I can stare at my avatar and my wallpaper for the rest of the night. I can sniff the outside of the case if I get desperate...........yep, it smells good! |
Justnoldbluzman
Thu Dec 18, 2003 9:18 pm |
The guitar came from the Illinois area where it is probably 35-40 degrees and went to where it is 50-60. Winter air by nature is dry 35-40% humidity, I am sure Alabama is probably around 55-60% humidity right now. Not knowing what type of heat you have in the house or if you have any additional humidifiers running it just isn't worth the risk. I have forced hot air in my home and I have to run a humidifier to keep the place at 58% humidity. I saw a brand new guitar split the top on itself in a matter of 6 hours one day because it wasn't acclimated right(granted it was an acoustic) but it was a CF Martin and it was mine. So believe me it can happen.
Bill |
Thu Dec 18, 2003 9:29 pm |
Extreme temperature fluctuations (for example, from outside temperature like in the back of an open ended UPS truck to your warma dn toasty 80 degree house) can cause some mild warpage in the neck (easily fixed-trtuss rod), checking in the finish (hard to fix, more prone on real nitro finishes and hand rubbed finishes), and frets to work their way loose as the metal heats and cools at a differant rate than the surrounding wood. It would be advisable to wait. If you want to open it in the morning, that would probably be allright. If it's been in your house a good 8 hours, you can uunhook the latches, and let the air flow in naturally, but DONOT OPEN THE LID as hard as that may be, that would be too much warm air in all at once. With the latches open, you'll be A-OK to play her in the morning before you head to work or whatever. HTH! |
_________________ Custom Dean "ankh" ML
z dogg
Thu Dec 18, 2003 9:32 pm |
That's terrible about the Martin. Who would think that could happen! Well, I had decided to keep baby in the case after you gave your first reply Bill. Now, maybe I'll even give it some extra time!
Dinasty, if I pop the latches, I know I'll open it!! I can wait.
Since I can't play the Z, I created another avatar.  |
