Nick M.
Mon Dec 22, 2003 7:03 pm |
hey all,
i don't have enough money for the 100w randall, oh well, i'm happy with a 75w amp, but... how loud is it? is it loud enough to play a school gym? loud enough to make my ears ring if i play it in my bed room?
thanks
nick
ps: the model is called RG75 (at least i think it is...) |
Mon Dec 22, 2003 7:16 pm |
Watt consumption is not a measurement of volume. It can be uesed as a relative measurement, for example, two class b power amps, one 30 watts and one 50 watts, it is generally safe to assume teh 50 watt will be louder.
I think you will find 75 watts is loud enough for any small to medium sized club with a decent PA. It will be PLENTY loud enough for your bedroom, and will not quite be loud enough for a school gym.
Question; Combo or half stack? Call em nuts, but I've always felt you got a better sound and more "ompf" out of a half stack... So a 75 watt combo amp will be swallowed in a gym, unless you're the only one playing. All in all, I'd say it probably big enough for everything you could need it for unntill you're playing 500 seat establishments. HTH! |
_________________ Custom Dean "ankh" ML
Nick M.
Mon Dec 22, 2003 7:19 pm |
it's a 1x12" combo. i'm hoping it will be loud enough for a school gym, but hooking up the amp with mics wouldnt be a problem.
thanks joe! |
Mon Dec 22, 2003 7:27 pm |
If they will let you mic it and are running it through a PA in a full abnd situation, You're all set. If you're talking about pulling a Doc Ozz Solo Star spangled banner, since you're the only one playing, it'll be fine as is.
Best of luck! |
rustyguitar
Mon Dec 22, 2003 8:05 pm |
i play out of 75 watts and its loud enough for anything usually |
Rex Herring
Mon Dec 22, 2003 9:03 pm |
I've played the Randall RG75 and it's plenty loud. It'll depaend on amount of people in the gym plus how loud the rest of the group is. It does have a speaker extension out on it so you can add an extra cabinet to increase the volume and cover more area. It'll push a 4X12 cabinet just fine but I have a single 12 cabinet that works for anything I've done plus there is a line out to run into a PA board. |
_________________ DOA# 02-0015
DOA Caddy #17
"V-WING" #17
Razor NT-5
DOA Hardtail Bass #6
Both Sledge Hammer 5 Strings
Dean Edge Q-6 Flame Top
Dean Edge 1 - 5 String
Dean Rhapsody 4 |
throbgod13
Mon Dec 22, 2003 9:19 pm |
depends on the efficiency of the speakers and the cab..
if you use a single 12", in a sealed box, and the efficiency of the speaker is 88dB 1W/1Metre, then with 1 watt input, you should produce 88dB.. it's all logarithymic.. to get a 3.33dB increase in output, you'd have to tenfold the power..
blah, blah, blah...
read this.. it's about "audiofile" speakers, but the basic info is sound..
http://www.lansingheritage.org/html/jbl/reference/technical/efficiency.htm |
_________________ DOA #01-0019
03 Demonator |
guitarforceone
Mon Dec 22, 2003 9:39 pm |
If you're going to play in a gym, you are in for nightmare acoustics. There will be so much reverb you'll get lost in the slop.
Dana <~~~ |
_________________ DOA #02-00111
'82 Baby Z Pinkburst
'9? Icons Amberburst (3)
'85 Jackson RR Custom
'86 Jackson San Dimas Str*t
'86 Charvel Model 4's (6)
'87 Charvel Model 6
'90 Charvel 650
'05 Charvel San Dimas
Marshall heads (7) etc. |
Nick M.
Mon Dec 22, 2003 9:40 pm |
Very cool! I'm not sure which amp i'll get, I'm very tempted to get the 100w 2x12" combo! I took out $600 in cash today to buy the amp, and my parents dont know. they're going to be really really really really really really really really pissed off when i come home with it on boxing day!!! |
Pulse Of The Night
Wed Dec 24, 2003 6:27 am |
Volume isn't nessesarily measured in watts or even ohms for that matter. One large factor in volume is the amount of speakers you're useing.
Say you have a 75w amp with one speaker and a 100w amp of the same brand with one speaker of the same size as the other ( or any other brand for that matter) and you have the preamp set identicle. You wouldn't notice much of a volume differance.
Now, lets say that you have a 75m amp with two speakers and a 100w amp with just one. The rigs are set the same. The 75w rig with two speakers would sound louder then the 100w rig with one speaker.
Hope that helps |
_________________ If you love someone, set them free. If they come back, place several 8 inch blades through their head. If they return again, run...just run. |
mr_ed
Wed Dec 24, 2003 7:51 am |
Nick M.
Wed Dec 24, 2003 7:42 pm |
| Pulse Of The Night wrote: |
Hope that helps |
yeah that's what i was thinking! i guess the 2x12" moves more air i guess..
we'll see if the guy at the guitar store will sell the amp for $600 no tax! |
hsech
Fri Dec 26, 2003 1:23 am |
Loudest small amp I've ever played through was a Peavy LA 400. 210 watts through a single 12" Black Widow. Did a lot of outdoor gigs with it and never had problems under any circumstance. Now I have a Fender Stage 100 DSP that has a single Celestion and it IMO is loud enough for anywhere. You can add an extension cab to it with a single 12" Celestion and that brings it up to 160 watts at 4 ohms which is more than overkill for anthing I play. Keeping in mind that I'm 55 and playing that loud in a band just isn't my thing any more. I'm playing for older audiences now and no matter what the amp is set on it's always "turn it down".  |
_________________ 2004 Fender 50th Anniv Deluxe Strat
2002 Gibson ES-135LE
2006 Fender 60th Anniv Std Strat
2006 Schecter Stiletto Elite Bass
Mesa Boogie Studio Caliber DC-2
Mesa Boogie WalkAbout Scout Bass Amp
DOA# 03-00197 |
Nick M.
Fri Dec 26, 2003 1:28 am |
Well tommorow I'm off to the guitar store to buy my amp, which ever one it is, you can bet it will be LOUD! |
Grumpy Goat
Fri Dec 26, 2003 4:00 am |
Wicked. Don't be put off by those who belive you have to have high nos of watts to get a big sound. My amp head is only 50w and it crushes our Rhythm guitarists 120w. Just play em and find the right one. |
MKK #9
DizzyDean
Fri Dec 26, 2003 12:13 pm |
Watts doesn't mean a whole heck of a lot volume wise. My 50 Watt Hiwatt 1/2 stack will blow just about any combo out of the water volume wise.
Go to the store and turn it UP UP UP - the sales guys will love you.
Or - ask for the amp that goes to 11!!! |
_________________ DOA 02-00007 |
