Hwangman
Thu Dec 25, 2003 6:07 pm |
I just bought a slightly used Edge 4 bass and tried it for the first time this morning. The 9v cavity was empty, but i assumed that it didn't need that to run...no sound when plugged in. I put a new 9v in and suddenly the bass was working fine. My friend has a comparable bass (active), and when his 9v dies, the bass runs as passive...apparently mine does not.
Does the bass require a 9v at all times, or can it run as passive and mine just has a electronics problem? |
_________________ DOA #03-00223 |
Instigator
Thu Dec 25, 2003 8:04 pm |
Bass needs a battery at ALL TIMES. No problem with yours.
Just remember to unplug your bass when not playing as this will drain the battery. |
_________________ DOA #02-00027 |
CliffBurton1986
Thu Dec 25, 2003 9:10 pm |
| Instigator wrote: |
Yea I found that out the hard way Anyway yea you always need a battery in it or else you won't get a sound at all. My Q5 has one and the first time it went it died slowly and i thought my amp was dieing then I remembered the battery and the sound returned . Just watch it when you change the battery. You mut inadvertenly loosen the wires and then you'll be screwed and have to take it in (which is where I am right now ) |
_________________ DOA # 03-0192
'01 Dean Edge 1 4 Str TAB
'02 Dean Edge Q5 5 Str QR
'07 DOA HT 5 Str #8
'03 MK Firefly 5 Str QB
'92 GK 800RB
'02 Bag End Q10X-D 4x10 cab
'03 Zoom 607
'04 MXR M-80
R.I.P. Condemned Already '03-'06 |
Hwangman
Fri Dec 26, 2003 12:39 pm |
Well damn.
Thanks for the help, guys. |
