 Are Kent Armstrong pickups any good? View next topic
NickM
PostPosted: Fri Jan 09, 2004 11:11 pm Reply with quoteBack to top
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=2370400952&category=22670
Any help would be great Very Happy
thanks!
nick
'DIMEBAG' DARRELL ABBOTT - 1966 - 2004
REST IN PEACE
DOA#03 00125
throbgod13
PostPosted: Sat Jan 10, 2004 1:03 am Reply with quoteBack to top
they are pretty decent from what i have read..
make sure that they are fully potted.. (i.e. dipped in wax) these are really high output pickups, and without potting, your asking for alot of feedback and squealing.. unless you cover them with a pickup cover..
i don't know what the specific tone of these exact pickups are..
you pretty much have to match the pickup with the acoustic tone of the guitar that your installing them into.. i.e. the pickup cannot compensate for what isn't there to begin with..
sticking humbuckers in a strat, won't make it sound like a les paul.. it sounds like a strat with humbuckers..
but, the right pickup installed in a guitar can make it unreal.. so, if your guitar has a LP tone, then you probably want a pickup to accentuate the natural tone of the guitar.. beefy mids, thick lows, and full highs..
usually the manufacturer has specfic sets that will get you closer to the tone that you want..
remember, most modern amps are extremely high gain by 70's standards.. so, you probably don't need a extremely high output pickup.. it's not going to give you a decent tone.. if you are running through a bunch of pedals/fx, then you might want a *higher* output pickup..
it's all a game of balance.. too much in, and you get crap coming out.. too little and it becomes thin and empty..
email Kent Armstrong and ask for a suggestion on what would be a decent match for your guitar..
anyway, these might fit your overall tone that you want to build..
good luck..
DOA #01-0019
03 Demonator
NickM
PostPosted: Sat Jan 10, 2004 1:32 am Reply with quoteBack to top
cool, thanks!
my amp is pretty high gain, so I dont need anything with a rediculous amount of output. I'm considering EMGs, but they're kinda expensive Confused
I also don't know if they'll fit into my Z, I hear that some guitars have to be routed for the electronics to fit. I'm also thinking about Bill Lawrences.
ahh so many pickups, so little money!
REST IN PEACE
DOA#03 00125
PresidentDave
PostPosted: Sat Jan 10, 2004 2:52 am Reply with quoteBack to top
I own a guitar with Armstrong pickups....don't much care for them . I have to crank my amp about 3 more notches to get the same level as dimarzio's.
ABBA......Now THAT'S real music !!!!
Dim3
PostPosted: Sat Jan 10, 2004 3:50 am Reply with quoteBack to top
All i say is Bill Lawrence...
throbgod13
PostPosted: Sat Jan 10, 2004 7:28 pm Reply with quoteBack to top
NickM wrote:
cool, thanks!
EMGs are fine.. yes, you do have to find space for the 9V battery.. this is a problem with *ALL* Active pickups.. EMG does make passive pickups.. the HZ's.. some seem to think that they are a "lesser" pickup.. incorrectly comparing them to the "Select by EMG" pickups (horrible pickups, imo).. the HZ's are USA made, and depending on which model, and how you wire them in, can sound great.. i've installed a set of HZ/H4's (H4 neck & bridge) in my DOA Caddy.. they are essentially, passive 81's.. and the H4A is the passive 85..
mine is like a passive EMG-KH21, Kirk Hammet set.. but with the coil-tapping like the Caddy has..
i've seen sets on eBay for $50.00-75.00 for a SET..
you can always install the "EMG-AB" afterburner in your guitar for a heavier punch.. or, the switch-less "EMG-PA2" to actually have a real pre-amp in your guitar, this will essentially make your HZ's into a active-like setup..
i'm not going to kid you.. they are bright.. you will have to play with different value capcitors and pots to control the edginess of the pickups.. but when you get them dialed in, they can be really nice..
they are sensitive.. somewhat like playing a singlecoil guitar thru a class A amp.. everything is very clear, and if there is slop in your playing, it will come out.. so, be aware of this before considering EMGs..
other than that..
DiMarzios are great pickups.. i prefer the vintage late 70's pickups for obvious reasons.. but the new stuff isn't too bad..
and Duncans are great pickups also.. they have a more "woody" tone to them across the board, opposed to the DiMarzios.. of course, this is my opinion and there are opposing views to this..
look around for guitars of similar construction, and look at the pickups and try to get a general feel for what you'd want..
if it were me, i'd stick a set of zebra DiMarzio Super Distortions (DP-100) in there and enjoy it.. (changing out the all electronics in the guitar too..)
good luck again..
DOA #01-0019
03 Demonator
NickM
PostPosted: Sat Jan 10, 2004 7:57 pm Reply with quoteBack to top
cool, thanks for your help!
i'm probably going to buy 2 Bill Lawrence L-500XL's. They're $50 now, instead of $48. Oh well, only $2. How long is the waiting list for those pickups?
REST IN PEACE
DOA#03 00125
throbgod13
PostPosted: Sat Jan 10, 2004 8:11 pm Reply with quoteBack to top
between 3 to 6 weeks..
and it's 14.50 shipped to The Great White North.. eh..
got poutine??
DOA #01-0019
03 Demonator
NickM
PostPosted: Sat Jan 10, 2004 8:18 pm Reply with quoteBack to top
got poutine??
hahaha poutine is awesome eh!
$14.50? will that cover the shipping for 2 pickups?
REST IN PEACE
DOA#03 00125
PostPosted: Sat Jan 10, 2004 10:51 pm Reply with quoteBack to top
Hey Nick - on the subject of Bill Lawrence pups you might want to consider a L-500XL for the bridge and a L-500 Rhythm for the neck. I have this set in a maple bodied Strat and it's a very nice setup with a lot of range. I have mine wired up with a 5 way super switch & a push/pull tone pot (only 1 volume & 1 tone on this Strat) The push/pull is for phasing Cool
Image Image
DOA member #0200106
NickM
PostPosted: Sun Jan 11, 2004 12:08 am Reply with quoteBack to top
How does the rythym sound clean? the neck pickup on my dean right now sounds pretty cool, but a little muddy..
REST IN PEACE
DOA#03 00125
throbgod13
PostPosted: Sun Jan 11, 2004 11:50 am Reply with quoteBack to top
got poutine??
with a cold Black Label, and a spork, mmmmmm...
Poutine Rocks.. eh..
the 14.50 thing is on the lawrence site.. i suppose that they would send two pickups for that..
of course, you have customs to deal with too..
DOA #01-0019
03 Demonator
PostPosted: Sun Jan 11, 2004 12:05 pm Reply with quoteBack to top
I believe their shipping prices cover 1 to max 5 PU's...at least it used to be like that!
DEAN ML flame BB 1981
PostPosted: Sun Jan 11, 2004 5:38 pm Reply with quoteBack to top
The L-500 Rhythm is a great pickup - not muddy at all IMHO great output and depth of clarity. I think these are some of the finest pickups I've heard bar none. Very Happy
Image Image
DOA member #0200106
