 Basic recording methods/techniques View next topic
georgec
PostPosted: Thu Feb 09, 2012 2:11 pm Reply with quoteBack to top
OK, I'm a total noob when it comes to any kind of recording software and interfaces, so bear with my ignorance...
I would like to do some very basic recording just to put down some simple ideas I have. Nothing elaborate needed, just tinkering around in the bedroom.
I don't know squat about DAW's and such. What I would like is a simple way to create or import a basic drum loop or two, and play a couple of guitar tracks over it, then be able to export it to an .MP3 file (or other audio format).
I have a Line 6 POD HD500, so I know it can act as it's own interface to most DAW's using the USB interface, and I have all of my presets available to me so I presume that I don't need any other type of hardware interface to get guitar sounds into my computer. I don't have a bass guitar, but I've thought that perhaps I could pick up something inexpensive to use with the HD500 to also lay down some very basic bass rhythms.
I guess my biggest question is regarding drums/percussion... Is this something simple to do with many DAW's? Do any of them have built in drum samples/loops I could simply use as a basis for recording basic songs? For example, I'd like to maybe pick out a 10-15 second loop, make it repeat a set number of times, then go to a different one that repeats for a set time, then back to the first, etc... I'm hoping I wouldn't need some kind of different drum machine or anything. Does that make sense the way I put it?
Like I said, I'm looking for basic information. I don't have mad guitar skills or anything, nor do I have any aspirations of writing the next big hit or becoming the next big thing. I'd just like to be able to record some basic songs of my own and be able to play them back without spending a fortune on recording equipment or going through a steep learning curve to use complicated software when I could be honing my limited guitar skills a bit.
PDogg81
PostPosted: Thu Feb 09, 2012 3:27 pm Reply with quoteBack to top
You can download Audacity if you're on PC for a multi track recorder and send your POD output to that if it's got a USB or line out.
For drum tracks I've used FruityLoops in the past, but you can probably use guitar pro or cakewalk to make up midi tracks and then record their output in one of the channels on audacity.
For recording myself I've only used the basic sound recorder and a mic to put down ideas, so I don't have any experience hooking in the drums and such.
DOA #09-02123
Dean Razorback Shards
Dean SplitTail w/ Floyd
Dean Deceiver F
Dean XXX ML
Dean DCR Zero
Epiphone G-310 Antique White
Epiphone G-310 Ebony
boombazilla
PostPosted: Sat Feb 11, 2012 3:32 pm Reply with quoteBack to top
This will let you do step by step drum patterns, it also uses .wav samples so you can just drop in new drum sounds.
http://www.leafdigital.com/software/leafdrums/
I don't think that the demo expires, so you can use it for a while and pay for it when you decide that it's a tool you want to keep.
Links to other samples:
http://www.leafdigital.com/software/leafdrums/drums.html
PostPosted: Sat Feb 11, 2012 4:32 pm Reply with quoteBack to top
Polarbear wrote:
Line 6 UX2.
Amplitube.
Mac.
Sorted.
I doubt he's gonna splash the cash on a brand new Mac just to do some recording, mate. Laughing
audiox
PostPosted: Sat Feb 11, 2012 6:56 pm Reply with quoteBack to top
Polarbear wrote:
Line 6 UX2.
Amplitube.
Mac.
Sorted.
Why would he downgrade from Pod HD500 to UX2?
Anyway, since you already have HD500.
Get EZdrummer or something, which has built in drum loops you can drag and drop and jam to, and create simple but cool drum tracks with the premade loops.
~DOA #11-02432~
georgec
PostPosted: Mon Feb 13, 2012 1:21 pm Reply with quoteBack to top
Thanks guys, I'm looking forward to trying a few things out!
Andro
PostPosted: Mon Feb 13, 2012 3:51 pm Reply with quoteBack to top
Er, the HD500 has a direct USB to computer no ?
Download reaper, set the HD500 as input source and you're done. Reaper is a DAW with a complete evaluation, not a crippled one, and I gladly paid the measly 60$ to get a registered version.
PostPosted: Mon Feb 13, 2012 10:45 pm Reply with quoteBack to top
acid pro is super easy to use ive recorded whole albums with it all u need is a computer interface. i have an m-audio box like a 150 bucks at gc.
Klebitz
PostPosted: Tue Feb 14, 2012 2:02 am Reply with quoteBack to top
My setup
Audacity
iPod Touch microphone
Beatcraft Drum Machine
CHA-CHING Laughing Laughing Laughing Cool Cool
'10 Dean VMNT1
Peavey Vypyr 30
Crybaby KH95 Wah
View user's profileSend private messageSend e-mailVisit poster's websiteYahoo Messenger
georgec
PostPosted: Tue Feb 14, 2012 12:48 pm Reply with quoteBack to top
The Reaper software looks interesting... I may download that this afternoon when I get home from work and give it a go. Cool
