OWNER
Thu Dec 16, 2010 9:36 am |
Hey there, forum fellas..
Scroll downwards
& enjoy the latest updates!
1986 Gibson USA® "Concrete Sledge" SG Special (3-Knob Limited)
Specifications:
* Body and neck wood: Mahogany body, Maple neck
* Construction: Set-Neck
* D.o.B: 08 / 11 / 86
* Bridge style: 85' Floyd Rose® Flush Mount + R3 Nut (Chrm)
* Tuners: GuitarFetish Keystone (Blk)
* Neck shape: That Fat Gibby "C" shape..
* Fingerboard material: Ebony
* Inlays: Medium Pearl Dots
* Frets: 22 x Medium
* Controls: 2 Volumes, 1 master Tone, 3 way switch
* H/H Pickup configuration: EMG® 81 / 85
* Strap: DiMarzio® StrapLok (M81 Woodland)
* Original Finish: Alpine White
* Epiphone SG Case (traded a 70cl cognac.. lulz!)
With it's previous finish, "Bukkake I".. taken late 2008
Randall RG180DX / Century3000 Amp Demo : Groove Metal Riffage!
1988 Gibson USA® "Bukkake II" SG90-Double (Steinberger™ Model)
Specifications:
* Body and neck wood: Mahoney body, Mahoney neck
* D.o.B: 04 / 11 / 88
* Bridge style: 88' Steinberger® KB-X
* Tuners: Grover Deluxe (Blk)
* Neck shape: Very Thin & Fast..
* Inlays: Twin Triangles
* Frets: 24 x Medium
* Controls: 1 Master Volume, 1 Master Tone, 3 way switch
* H/S Pickup configuration : Gibson® 500T / Meymour Duncan SVR-1®
* Strap: DiMarzio® StrapLok (Blk)
* Original Finish: Alpine White w/ Perloid Pickguard
* Gibson SG Case
1993 Peavey® Rockmaster Rack Tube Preamp
Review:
1U Rack unit, All tube preamp..
Very light, easy to use, simple exterior & interior design.. but, LOTS of features. You see all those little knobs? 25% of them are push/pull..
This means, let's say you've got the three regular types of channels; Clean / Crunch / Modern
What kind of sound you obtain isn't limited to the 4 band Eq you see on the left. There's still the 3 knobs to the right.. wait, not yet!
You still have push pull knobs within these Eq / Voicing pots which drastically change the overall tone you're getting..
Wait.. wait! Still not over yet, plus you can pull those Gain controls! These add even more gain over on top to what a regular channel jump does.. I'd count this preamp a 5 channel preamp.. it's got insane amounts of drive! No wonder they labeled it; Ultra
If I was asked to rate this thing, I give it an instant 10/10
Why? Well, all I said above is the front panel.. At the rear; you've got exactly 10 Jack inputs, just for the FX Loop section; every channel has got it's own Send / Return.. siding a Common Send / Return to affect the complete amp.
Next to all this, there is a little switch for all us 110v players.. You can adjust accordingly to get rid of the 60 cycle hum.
Push everything aside; the front is labeled with Pink & Cyan..
Now.. is there anything more 90's than that??
Additional pr0n:
Newly ordered 12ax7 Tubes resting over itself..
Gut pr0n : Replaced a potentiometer & installed the 12ax7 EHX & GrooveTubes in.. Killer sound now!!
1991 Randall® RG-180 DX (Early Century3000) Combo Amp
Review:
They're considered as the "Post-ES" series, right before Randall introduced the Century models in early 1992.
The preamp and power amp structure of the RG-DX & Century's is the same as the older RG-ES's for the most part. The Century has some slight differences in high frequency filter cap values and other power-amp upgrades but for the most part the tone generating components are 101% identical. I have personally seen the schematics on this amp and they clearly state that the Randall Century 200, Century 3000, RG180 DX and RG200 ES all share the same schematic.
The late; Darrell "Diamond / Dimebag" Abbott is hugely responsible for the popularity of these metal beasts, as people who are familiar with TAMPORA know these were the amps used to record the "VDOP" & "Far Beyond" albums.
These Irvine era Randall's are the very few solid-state (FET) amps to hold their own amongst the many popular valve / tube amps.
Like all solidstate Randall's.. VERY sturdy & loud! Around late 2010; I blew the fuse + preamp + power-amp section due to plugging it into a 220v socket by mistake, and after replacing a few diodes & the 3A fuse, not only did it get resurrected, it even sounded better!
I was lucky to get hold of it along with it's rare FS-5 footswitch that allows you to change channels from the green channel to the red channel and also select both channels at the same time. Having both channels going at the same time gives you incredible flexibility over the overall sound of the amp, along with Bright (Treble) Boost, Mid Boost & Sustain (Gain) Boost options. I also own a even more rare 2U Rack version of this amp modeled as; Randall RGP1000, and the DX is superior in my book, although the RGP has an insane dual layer Chorus feature.
Love it! More than my Peavey Rockmaster..
Well.. sometimes that is!
Ultra Rare Owner's Manual:
Randall Century 3000/200 & RG180-DX Manual .pdf
Additional pr0n:
Stripped like Robocop2 !!! Joke aside, you all know I love washing my amps.. (notice the rusty reverb tank!)
Gut pr0n : brushing all the excess soldering lead off the circuit board. There's the trimmer pot which needed to be biased to -.6v as suggested..
Installing the new Accutronics® Reverb tank I had ordered.. (Notice the Randall Jaguar™ Deluxe 12" Speaker - 8 ohms)
Installing heavy duty casters.. done bara bra! ^^
2006 DigiTech® "HULK BLOOD" WH-7 Whammy (Heavily Modded)
Review:
Long story lying under my Whammy..
Traveled a lot more road than me or you.
When I got my WH-4 out of it's box, I plugged in and of course immediately ripped into the +2 octave module & started plucking "Tampora - You've Got To Belong To It".. I'm playing along.. things were too squeeky! I thought it would be because I had plugged into my Whammy first, than flat-boosted the signal with my ol' MT-2 back then (Kirk wannabe me, tut tut).. I swapped the cables around, things sounded better but while I detached the pedal, I felt there was some sound loss with the Whammy in the signal.
Anyway, plugged back in.. kept playing everything was great.. but, what's that slight delay? After a while it started to get on my nerves. I was loosing it, I just wanted it to be perfect. I thought it ought to be because it was a darn "re-issue" pedal..
I start searching all over the net..
Everyone was complaining about the WH-4 latency problem. The way it sucked out tone.. I figured it was an universal issue, and since everyone was praising the original WH-1, I decided to go for it! I left bulletin posts everywhere, including domestic websites & shops that I'm in search for the original..
I get an e-mail, this guy says he's got the WH-1 in good condition, can sell for a reasonable price. Then asks me why I'm so obsessed with the WH-1, I stated all above. He apparently has been doing amp + pedal modifications in Turkey for pretty long, and also to big shot artists around the world.. so this dude wants me to send in my own WH-4, he shows reference & promises he would handle all issues & convinced me that the WH-4 is superior, both in body mass to the original, plus that it's more functional; for instance having a MIDI connection..
After a week, back comes my Whammy.. a nice oiled up treadmill & with this additional switch smack in the middle? I sit down and try it out;
- Latency gone.
- Calibration switch added.
- True Bypass function instead of the regular on/off.
I was scared.. hell glad to meet this genius!
Then, having to be really bored of red, & Kirk Windstein my idol.. I decided to go for this disgusting snot green.. and pay tribute to my childhood hero "HULK BLOOD".. trashing hotels & managing to stick chairs into exit lamps.
*QooiK!!*
Additional pr0n:
Cut off the rubber studs.. applied "helipad velcroing"..
Back when I broke the switch. Got the replacement parts..
During surgery : also decided to install Blue Led's to the "DETUNE" section, as I use it for some lazy instant Chorus..
It.. is.. A L I V E !
HULK BLOOD WH-7 : a glance from over..
HULK BLOOD WH-7 : Logotype at front.. "Qooik!!"
Thanks for your time! |
_________________ *QooiK!!*
Frogman
Thu Dec 16, 2010 3:43 pm |
Is the Century 3000 rack mounted??
What's the rack-mounted amp I see at the beginning of the video? |
Spite
Thu Dec 16, 2010 3:56 pm |
Thats an RGP1000.
Basicly a RG100es preamp with some other features as I understand it. |
| Grim Reaper wrote: |
| The only cure for GAS... is DEATH! |
Frogman
Thu Dec 16, 2010 6:07 pm |
OWNER
Fri Dec 17, 2010 12:18 am |
The Century3000 is a Combo version of the Century200 amp,
These two models share a completely identical preamp structure as the RG180DX and RG200ES models..
The only differences are within the poweramp, which are not noticeable (unless you really know your electronics), the Jaguar > Celestion speaker change & cosmetic changes; like the front panel labeling & red knobs.
Spite is correct,
The blue faced 2U Rack in the beginning of the video lying on top of the combo is a Randall RGP1000 Preamp Unit.
Well, we can't call it a "RG100ES", as those digits represent the general output of their model (like 80,100,200..) Calling it the Dual Layer RG-ES Preamp would be more true, as it's output varies according to the poweramp you've plugged into.
It's like having two of the old Randall amps in one rack unit, with all the boost options & analog chorus module for each layer. Like you normally can do with the channels, you can blend both green & red amp layers and come up with even more wacky stuff; with extreme chorus/reverb, or getting a sound like your playing underwater, by dialing opposite Eq settings. I have a review thread on the RGP1000, here is the link to it.
All these Randall models mentioned are solid state.
They're all Pre-Washburn made & sound similar to each other, with the Presence knob being the most recognizable feature; Yes! Making the amp sound from high-gain Crowbarish, to that JCM800 bold rock sound to that trebly Pantera sizzling distortion. It's all there, when you build on it with external Eq'ing and drive pedals.. you can convert it to anything you can imagine.
You don't need any of these external toys with the Peavey Rockmaster, it does it all by itself.  |
Fri Dec 17, 2010 1:08 am |
OWNER
Sat Dec 18, 2010 6:52 pm |
| www.DropD.net wrote: |
| My 1st randall was the rg-180. it ripped!! |
You were the first brother I asked when I came across the combo amp..
I have to specially Thank You Trix, for insisting I grab the RG180 DX..
Was a move as good as; ▼ + ▼► + ► + B
P.S.¼: Did you let yours go? If so, why did that happen? |
Sun Dec 19, 2010 12:36 am |
| OWNER wrote: |
I bought mine. It was cool, but in 1998 I had my rg80-es mini stack in mint condition become available and I decided to sell the rg180dx.
I still miss it but I didn't know what I had back then.
The rg180dx was $300 when I bought it.
I prefer up,up,down,down,b,a,b,a start
or 007 373 5963 |
_________________ ChampionPedals.Com
OWNER
Wed Dec 22, 2010 11:44 am |
People have been asking me about the Gibson 86' SG..
It's got some story beneath it. I was after this guitar over some local forum 2-3 years back actually.. day after day, I always tried buying it off the guy who owned it back then. Never was able to convince him..
After some time, we met by coincidence at a gig downtown.
This ol' school rock band was doing it's thing, and this guy wasn't watching the band play. I noticed he was just starring at the guitarist's Ibanez PGM which was on the stand at the side, with a beer in hand.. just gazing..
I had a Dean Explosion Razorback in hand if you remember. So, I planned & managed to cross-trade;
Dean Razorback > Carvin 89' DC200
Carvin 89' DC200 > Ibanez 90's PGM
I've got a picture of the Carvin DC200 here , it was pretty good!
Although it's really easy to write all these down, believe me it took time.. like four of five months to come across each guitar above..
PGM.. hated the guitar, you know the white one with black f-holes, maple neck.. skinny as feck.. anyway, checked the soldering & replaced the strings.. adjusted everything.. restored it.
So, the next day I get the guitar in hand, I ask the guy to meet up at a studio & jam, improvise.. he comes over, pulls out the SG.. (I drool..) starts warming up, then I pop out the PGM..
He started sobbing, couldn't even talk properly.. "pass it over, pass it over!"..
because it was a dream for him! Made in the early 90's, color has gone yolky.. superb condition.. I pass it over rolling my eyes..
I was sure he was going to love it. After he played for a while, I sat on the combo amp, made him the offer, "You take the PGM home, I just want the SG.. today.. now.."
The "studio session" was cancelled that moment,
Although it practically took me a year, that's how I got it !
It's a limited "3-Knob" edition of the Special series. Alpine White color gone bone-like..
lots of hits & bashes, which I adore. With it being from the same era and made from a mahogany body, maple neck & an ebony fingerboard, it's what you can call the SG version of Hetfield's 84' Explorer.
Did a lot of modification, you can see the stock specifications here:
EverythingSG.com | Gibson 3-Knob SG Special
| The rg180dx was $300 when I bought it. |
Was that the sale price at a store, like brand new?
I've always wondered the pricing of these Irvine Randalls.. if they were reasonable or just Hungarian salami expensive.. |
Thu Dec 23, 2010 4:38 am |
No, That was used in pretty nice shape. I bought one out of the tradin time's mag we had here, but the same week I saw one at guitar center for same price in same condition. Only 2 I ever saw in person. |
OWNER
Sat Jan 01, 2011 9:33 pm |
As a New Year's update for my thread's followers,
Badass Lingonberry Cheesecake I baked using the Randalls..
Sat Jan 01, 2011 10:17 pm |
i want the hulk bloood |
_________________ DOA 09-01879
Dean Soltero Intimdator/jb stock neck |
OWNER
Sun Jan 30, 2011 9:14 pm |
NEW PROJECT : 86' Gibson Concrete Sledge SG
After years & years of silence..
Yep, I'm going for it!
Stripped it completely down, all electronics & metal parts.. including the fixed-bridge mounting stud bushing. The only non-wood material currently on are the frets.. Here's a video that helped a lot, mind you :
How to remove Bridge Bushings without damaging your guitar!
All has been planned;
I'm changing the positioning of the electronics, going to have the switch nearer to the bridge, like on regular SG's.. I'm hunting down a Floyd Rose®.. enough! I've had to make do with a Tune-o-matic for more than 3 years! My hands are craving to do a divebomb!!
I've applied some modeling cement, putty, whatever you call it.. on all the bumps, bashes & cracks from 24 years of excessive use. Removed all the paint & sanded it down. Changed the upper strap button location. Refined the edges & applied the first coat of white primer, as the colors are gonna be bright!
Sneak-Peek on the CSSG
OWNER
Fri Feb 04, 2011 7:47 pm |
I managed to score two sets of these 80's Floyd Rose Tremolos..
Heres an upskirt angle of the tremolo..
From all I've read, they're considered like non-recessed Floyd's..
directly mountable to fixed bridge guitars, no routing or cavity needed. Just pop it into the stop-tail bushings. The nut is up to you. I ordered a 43" Floyd Rose (R3 - 1.695") locking nut as the Kahler style would be weaker.
The whole project is spiritual masturbatory, so I have no problems with irreversible changes as I'm not thinking of selling this thing anyway!
..& Pinkburst applied on the CSSG
OWNER
Sat Feb 12, 2011 11:39 pm |
Most of the work has been done!
Applied a hefty coat of toffee gloss.. I made things continue a bit towards the rear,
including the.. ass cracks!
The thing I'd like to ask you all about is if direct mounting the pickups would effect the sound I get in any way?
Because I'd personally like the finish to show more, even did some shading around the humbucker cavities und covered up the mounting ring screw holes..
So please let me know about this..
& don't forget to vote up on the vince poll if ya got time!  |
splittailstealth
Sat Feb 12, 2011 11:50 pm |
That looks incredible!!!!! |
| ChadMang wrote: |
| I like to roll the nut seed around in my mouth and extract the hidden juices within. |
Jewel
Sun Feb 13, 2011 12:01 am |
Dude that came out really really really really really really really really really really good.  |
BBA
Sun Feb 13, 2011 12:03 am |
| OWNER wrote: |
Great job, man! Looks fantastic!
To answer your question, I'll lead you to J from White Zombie:
"I’d read an interview with Eddie Van Halen in a guitar mag where he explained his idea that anchoring pickups directly into a guitar’s wood body ( as opposed to mounting them in a pickguard or plastic pickup rings ) results in more tone, or harmonic richness, or something — which sounded plausible to me, so I had the guys at Ibanez do that. I don’t really know if it makes much difference, but it gives a guitar a utilitarian, ” chopped ” look that I dig."
http://www.jyuenger.com/?cat=6
DOA # 05 00473 |
audiox
Sun Feb 13, 2011 12:20 am |
I'd like the bukkake. Yummy.. |
_________________ ~DOA #11-02432~ |
Sun Feb 13, 2011 12:22 am |
I dig that Iceman hard  |
Sun Feb 13, 2011 12:27 am |
| audiox wrote: |
There's no way that one wasn't getting sig'd...
Looks AWESOME, Onur! Love the cracks around the knobs!  |
_________________ DOA Member # 06-00859 |
BBA
Sun Feb 13, 2011 12:28 am |
That makes you; me; Lanning; finnflash; gunslinger & a few thousand other dudes.  |
DOA # 05 00473 |
BBA
Sun Feb 13, 2011 12:29 am |
| MikeHock wrote: |
| audiox wrote: |
Bwahahahaha!  |
DOA # 05 00473 |
TCOH5246
Sun Feb 13, 2011 12:32 am |
I freaking love that finish.
I want Allan to do that to my Rhoads. |
Bullet
Sun Feb 13, 2011 1:05 am |
That SG is pretty bad ass. |
Sun Feb 13, 2011 1:27 am |
amazing man... *droooooool* |
_________________ 1979 Dean Z
DOA: 09-01874 |
wyd-open
Sun Feb 13, 2011 5:45 pm |
Wow, how did I miss this thread?
I guess the Sledge paint job works out well on just about any guitar. You did a killer job on that. BRAVO!!!!
I would go with the hard mount. Like you said, it has a more raw look that I think would work well in this situation. |
_________________ Many Deans, Many others
| MAB wrote: |
| Dean Guitars RULE. |
| Music isn't supposed to be a business, it's supposed to be art. |
BillPalmer
Sun Feb 13, 2011 9:57 pm |
Sun Feb 13, 2011 10:17 pm |
| BBA wrote: |
| OWNER wrote: |
Is that ICJ yours? I'm on the hunt... Sorry to threadjack... Just haven't had much luck for one in good condish... |
Sun Feb 13, 2011 10:37 pm |
That concrete finish is killer! |
BBA
Sun Feb 13, 2011 10:46 pm |
| Is that ICJ yours? . |
No, and:
| BBA wrote: |
And:
http://www.deanguitars.com/forum/viewtopic.php?p=1331079&highlight=#1331079
And if it were mine:
In the words of the late, great Charlton Heston, "...from my cold, dead hands."
DOA # 05 00473 |
Mon Feb 14, 2011 1:27 am |
Mon Feb 14, 2011 1:18 pm |
man i love the finish on the concrete SG, all those little details make it superb!! great work owner!!!!  |
OWNER
Mon Feb 14, 2011 1:38 pm |
Thanks so much for each & every feedback! I'm glad you all enjoy my work.. much appreciated!
The CSSG is not complete yet, while doing all this, I didn't need to worry about the paint drying as I got the biggest oven in the world.. this huge badass sun.. It's February & I'm wearing shorts, there has to be something wrong with that.. haha!
I'll be updating not only about the guitar, but also fellow members who are concerned about the flush mount tremolo system too;
if it functions properly, if it's worth to hunt down & throw that much ca$h at it..
The paint shrunk a little, there aren't any cracks, but some of the screwdriver holes weren't filled with putty, so the paint just happened so "sink" and dry within. I can't be bothered to go through another paint+gloss phase just because of some 2mm hole dents appeared around the humbucker cavities, so I'll just keep it out to dry until the shipment arrives..
the stink'll evade & it'll be rock hard by then.. (that's what she said.. )
@BBA: Thanks for the link! I've been after anchored pickups as a die hard George Lynch (maple syrup ♪ ) fan for years! So basically I'll be slapping all my long time fantasies on this guitar! Plus, you can't go wrong following Eddie..
@audiox: Tss..
@wyd-open: Thanks much! Do you think it's necessary to additionally bake it in an oven for a few minutes? Would it be a good precaution, or is leaving out to dry enough? I wouldn't want it to fall apart in my hands after a few weeks.. that'd suck..
P.S. : you may hijack my thread anyday, but please at least not with the Iceman.. I really HATE those things & can't stand having to see or read about it along with my favouri..
see, I don't even feel it's name worthy to be in the same sentence with the SG!  |
Culprit
Mon Feb 14, 2011 4:26 pm |
Awesome job Onur! It looks damn sexchey |
wyd-open
Mon Feb 14, 2011 4:44 pm |
If you can hang it out in the sun, there is no need to bake it. If you plan to wet sand it and buff it, sand it first with 2500grit and leave it sanded for 2 days. This will allow the solvents to escape faster and will give you a harder and glossier finish when it is done. |
| MAB wrote: |
783.2
Mon Feb 14, 2011 6:41 pm |
Wow.
Awesome paint job!
The black cracks and outlines must of taken hours?!
Especially love the Gibson logo.
BBA
Mon Feb 14, 2011 10:33 pm |
| OWNER wrote: |
Ironically, that is exactly how I feel about SG's and Strats and Telecasters.
But I can still appreciate badass work. Even if it is on an ugly ol' SG.  |
DOA # 05 00473 |
Mon Feb 14, 2011 10:50 pm |
awesome!!!!!!!!  |
_________________ DOA 06-00771 |
OWNER
Sat Feb 19, 2011 10:26 pm |
Can't wait for the Floyd Rose to arrive!
Thanks much again everyone..
I really liked the 2x Holy s#%t's it got, specially from people who knew it in person years back..
I've put it together to see how it sounds;
apparently, the whole re-finish effected the playability in a positive way, has a very fresh feeling.. that's a major "phew!"
I set the action low, swapped & anchored the pickups.. to be honest, the 85 sounds really good in the bridge position.. balanced the output as it was way too dominant at the neck compared to the 81..
has more chunk, can stay for now! Was considering switching back to passives, but the results I've gotten with both clean & drive settings are 101% satisfying. So, there is a difference in performance, I'm glad to say in a good way!
@wyd-upan: Thanks much, did as you recommended. Then after, buffed it several times with Turtle Wax.. smells, shines and feels great now! It has that damp-sharp look at all times compared to it's first few days..
@783.2: Time is a lot to spend here.. besides, I felt just like Ahnold during the whole process!
As for some "in action" pr0n..
The Beak Peck tapping stance:
JohnC
Sat Feb 19, 2011 10:42 pm |
Holy fuck! That looks awesome! |
Mika
Sun Feb 20, 2011 8:43 am |
That looks way beyond awesome and badass , I love it!!!!! |
_________________ DOA 06-0073 |
stuehmer13
Sun Feb 20, 2011 10:58 am |
gorgeous man... and that guitar isn't too bad looking either
I always thought SG's were a little too thin though to put a floyd on. |
OWNER
Sun Feb 20, 2011 11:58 am |
Thanks!
How did you manage to get that typed down, John? *+rep*
| stuehmer13 wrote: |
| ...I always thought SG's were a little too thin though to put a floyd on. |
It's going to be flush mount,
so, no worries since there's no body routing!  |
stuehmer13
Sun Feb 20, 2011 12:23 pm |
| OWNER wrote: |
Thanks!
| stuehmer13 wrote: |
Oh I see well I hope that goes well for ya. Enjoy that bad ass guitar!! |
Frogman
Thu Mar 24, 2011 3:33 pm |
Can't believe I missed this!
Now you have to do a step by step on how and what materials you used!  |
riklite
Thu Mar 24, 2011 5:14 pm |
I love the sledge! Glad to see people still giving THE MAN tributes. |
RANMAN106
Thu Mar 24, 2011 5:36 pm |
WOW!!!!!!  |
_________________ DOA# 08-01691
"I can still only name two Pantera songs when I hear them, but some of you guys know what the barometric pressure was in the studio during the recording of "Cowboys from Hell". It's all perspective" - Jim |
zzar333
Thu Mar 24, 2011 5:42 pm |
Sat May 14, 2011 9:30 am |
so hows it going with that flushmount floyd? ever got the chance to put it on?
Soundclips? |
_________________ DOA Number 11-02401
-"Blitz" aria pro 2 white les paul copie |
Afe
Sat May 14, 2011 4:08 pm |
Dayuum, that gibby is just too cool  |
OWNER
Sun May 15, 2011 10:13 pm |
It's been a while since I last czeched in!
Thanks much, brothers..
| DirtyHeritage wrote: |
Soundclips? |
Here's a new soundclip : Süper Damper - On'lar
Looped my self as the Rhythm guitar, added a layer of bass with the "Hold" option the Boss DD-7 offers.. it's just the neck pickup with the Tone knob rolled down, as I don't have a four stringer!
Excuse that it may sound a bit dry. It's home-recorded with the A.C. wizzing off at the back.. Engaged the "Mid Boost" on the Randall Century & chucked my own leads.. something different to listen to than the original..
in the end; I'm not Darrell, neither are you..
Here's a new vid shot with it : Desert Pool Jam 101%
Just randomly filmed while messing with a shitty lil' Marshall micro-amp poolside..
The retarded seller sent both Floyd sets with Kahler nuts..
So, I had to make do for a month or so like that. The tuning kept shifting a few cents per divebomb & that drove me nuts!
While gigging at one of the embassy gatherings here, I suffered trying to end every lead line with a slight yank on the tremolo bar, just to return back to pitch with the rest of the band.. (You can notice this also in the middle of the video posted above)
Anyway, the R3 Floyd nut I ordered arrived along with my major delivery. I am extremely proud to say that the Concrete Sledge SG plays flawlessly now.. handled the tuning stability issue to the bone!
Oh, I crashed into one of my dream guitars online at Fat Cat Guitars & grabbed it without thinking twice,
it arrived last week! (Scott, you rock! ) I wish you all the same excitement.. here's an updated groupshot pr0n;
- 1988 Gibson USA® "Bukkake II" SG90-Double (Steinberger™ Model)
- 1986 Gibson USA® "Concrete Sledge" SG Special (3-Knob Limited) |
Thu May 19, 2011 10:27 pm |
sweet man. that has to be one of the coolest sgs ive seen in a long time.....a long long time.
ive had my shot at that paintjob too. check it out. i think the worst part about doing this one was that my back was killing me from doing all the cracks.
Thu May 19, 2011 11:02 pm |
i liked it before the mod. but nice job on the paint and all. just not my thing. but its yours and as long as you dig it that is what matters. |
OWNER
Sat May 21, 2011 4:06 pm |
Since the modification process is complete; I've updated the whole thread with specs, reviews & some freshly baked pr0n..
I'm also very proud to say that Kirk Windstein & Grady Champion really liked the work along with all you brothers here.. It's a bodacious feeling to also get approval from your childhood heroes!
I was planning to also give the SG90D a Sunburst Tiger Purple Glittered refinish; but the guitar is just too damn good in condition for a re-touch.
Not only it's finish.. it just plays perfect, low action.. growling drive & pure single coil twang.. plus, audiox likes the bukkake..
| warmonger wrote: |
| sweet man. that has to be one of the coolest sgs ive seen in a long time.....a long long time. ive had my shot at that paintjob too. check it out. i think the worst part about doing this one was that my back was killing me from doing all the cracks. |
Means a lot to me, thanks much!..
Don't ask! You can notice the cracks on the headstock are much bulkier and n00bly done as that's the point I started going down on it.. by the time I reached the rear "asscracks", I had become more of a veteran & my hands weren't clumsy anymore. Things got precise..
Your ML looks amazing! More a tanned pallet you've used, the only factor that bothered my eyes (excuse if I'm wrong..) was that the burst looks like its "hovering" because of it's shadow.. you get me? Have black borders along with the shading.. it'll look more like its inside a bashed slab of concrete.. not like fruit peels over it.
What's the original guitar by the way?
| BLOODROOT wrote: |
I totally understand you & had a laugh when you noted down Fisher-Price before, because that's what I mumbled the first few days; when I woke up & gazed at it with one eye first thing in the morning.. bashed my head back into the pillow..
The fact is that the varnish melted all about, finish had peeled off, there were way too many cracks around the neck as it had broken off before.. trust me, it was at a point blobbing it into baby brown would have made it look more sturdy & sexy.. I respect the fact it's new finish may not appeal to everybody, but thanks for appreciating the effort!  |
Sun May 22, 2011 2:23 am |
| warmonger wrote: |
What's the original guitar by the way?... |
i guess i never noticed it but yeah your right, it does look like its hovering. to be honest though, that was the first burst ive ever done, i went out and bought an airbrush gun like a week before i actually sprayed it. the original finish on this was the Warbird ML. i hated the idea of having a decal, even though it was cool, on the guitar. im actually listing it on ebay cause i need money for another project (1984 gibson explorer restoration). but yeah anyways thaks for liking it |
OWNER
Sat Jun 04, 2011 8:31 am |
Although it took many years, I've managed to score a scan of the Owner's (ehem..) Manual for the Randall Century3000 / Century200 / RG180-DX model amps in .pdf format,
I've updated the first post with the download link. Printer friendly.. enjoy!
| warmonger wrote: |
| ..to be honest though, that was the first burst ive ever done, i went out and bought an airbrush gun like a week before i actually sprayed it. |
That is applaudable for a first go with an airbrush! In my opinion it's much better than the Warbird finish anyway.. congrats!  |
ATR1990
Sun Jan 22, 2012 4:50 pm |
Sorry to bump, Are you still selling the HULK BLOOD ?
Edit **
MY BAD Are you even selling it ?  |
GETCHA SOME ! |
OWNER
Tue Jan 24, 2012 7:35 am |
| ATR1990 wrote: |
Sorry to bump, Are you still selling the HULK BLOOD ? MY BAD Are you even selling it ?  |
..it is so full of brüt that it made you hesitate, change your question & now you've just answered yourself without even realizing yet..
Joke aside, If you want your Whammy or any amp/pedal cloned, restored, modded & is willing to ship back & forth :
Cihan's Workshop |
Tue Jan 24, 2012 12:47 pm |
man those SG's look definatly sick!!! man i never had GAS for any of these type of models but this just blows that thought away!! nice pieces of art man!! |
OWNER
Mon Jan 30, 2012 7:44 am |
dankjewel, brother..
Recently, I've removed the pickguard & it feels + acts even more 80's..
gives me this K.K. Downing side to side rocking spirit.. Here, let me share a few shots..
Oh, I'm working on shifting the RG180-DX (Century3000) amp layer into a Head format, so I've converted it's old box into a 1x12" Jaguar Deluxe cabinet. Put some side handles to ease the haul.. I'll get the head repaired/modded to meet the specifications of an Bogner Ubershall by Cihan hopefully due till June 2012.. when I go back to Turkey for my Summer vacation..
To sum up; a 220v Hot-Rodded Century200 amp in a "Mark IV" sized small head chasis just sounds scary..  |
Tue Jan 31, 2012 10:24 am |
man that slegde sounds beautifull trough the randall 150!!! dayum!!
i was amazed on how much emotion the tone carried with it!! really dig that guitar man!!
ps. that poolside jam is just hilarious!!! now that's what you do with those little marshalls!! their made to mess around!!
Good to see you on the forum again |
