StoicBehavioR
Mon Aug 13, 2012 12:51 am |
How can you tell if it's a real USA dean or not? Is there place I can go to type the serial number in to search.
Serial # 05 00932 |
It's legit. It's a real serial number, anyway. |
_________________ DOA 05-00439
Carvin V3/Metaltronix M1000 |
StoicBehavioR
Mon Aug 13, 2012 12:54 am |
| formula73 wrote: |
Thanks.. |
Mon Aug 13, 2012 1:07 am |
wstoll
Tue Aug 14, 2012 2:24 am |
SN# follows the correct format...but a Picture would be better.....specifically the end of the fretboard  |
_________________ DOA# 04-00279
81 USA Cadillac
82 Baby Z
02 25th Anv Caddy
05 P-90 Z
03 TC Caddy Custom
05 TC Exotic Z
06 TC Korina Z
All DOA Guitars
L.W. Sig #48
07 TC Korina Caddy
07 Soltero #22
07 TC Z
07 Lost 100 Z
08 Vinman 2K
09 USA Baby Z |
StoicBehavioR
Wed Aug 15, 2012 1:47 am |
| wstoll wrote: |
Wed Aug 15, 2012 5:19 pm |
USA Razor......Nice!! |
_________________ DOA#06-00983
Gibson Les Paul Standard
5150 Block Letter |
Wed Aug 15, 2012 8:13 pm |
weren't they stamped/pressed into the headstock as opposed to what looks like a decal in 2005? |
_________________ DOA Member 03-0191 |
StoicBehavioR
Thu Aug 16, 2012 12:03 am |
| transblueZ wrote: |
That's what I thought and the reason I posted to ask if it was real.. |
Thu Aug 16, 2012 1:37 am |
If it's an 05 as the picture shows then I believe it is one of the few guitars that US Masters made that was painted and then marked that way as they did on the Pro Series guitars. For instance here is one of my old US Masters Hardtails.
http://i259.photobucket.com/albums/hh319/lanningkann/Guitar%20Photos/IMG_0143.jpg
It was a USA Pro Series HT and Dean decided to paint a few of them. It would have been stamped on the back of the headstock but it was painted and then had markings like your Razorback because the paint covered up the stamp. If you chipped that paint away there is likely a stamp under it. They did limited numbers of lower grade US (not having any special binding or any high end accoutrements) guitars at one time back around then. Essentially it would have been a Pro Series or a MHG series but they painted it. I believe it's real.
I can't say 100% for sure why yours has those markings if it's an 05 as I haven't seen another Razorback with the date like that except the Rust RB that I used to own. It's a US Masters for sure though so the markings are real. It may have been a NAMM guitar. |
_________________ LIKE Wolfborne on Facebook!!!
Last edited by Lanning is Killdozer on Thu Aug 16, 2012 2:04 am; edited 1 time in total |
wstoll
Thu Aug 16, 2012 1:54 am |
As Lanning said....it could be a NAMM Guitar. It has the fret end bubbles in the clear along the Fretboard.....very US Masters! A lot
of those year US Masters Deans did this.
I will say that there is only 1 USA Razorback listed in the 05 Catalog
and it was the Rust. I am not sure in 05, they were doing Custom order Razorbacks but it is possible. |
81 USA Cadillac
82 Baby Z
02 25th Anv Caddy
05 P-90 Z
03 TC Caddy Custom
05 TC Exotic Z
06 TC Korina Z
All DOA Guitars
L.W. Sig #48
07 TC Korina Caddy
07 Soltero #22
07 TC Z
07 Lost 100 Z
08 Vinman 2K
09 USA Baby Z |
Thu Aug 16, 2012 2:03 am |
| wstoll wrote: |
Also a possibility it's a Rust that didn't get the treatment. That finish is the exact same silver my Rust was. The fret end bubbles also lead me to believe it's a Rust that wasn't finished due to the bubbles so it was sold as is as a B stock. I used to get a lot of USA B stocks as my stage guitars because they were just as good as the regular stock but had little flaws so were available at great discounts. Either way that guitar is awesome! I loved the US Masters Deans.
If you're still not sure, take a photo of the truss rod cover and then take a photo of it off. That will be very telling. The truss rod cover should have 1 screw. As far as with it off you can tell right away if it's a USA or a knockoff by how the truss rod hole looks. |
StoicBehavioR
Thu Aug 16, 2012 3:38 am |
So it probably was a display guitar. The guy is asking 1,399.99 for it, do you think that's a decent price? They state it was never played and "new." |
Thu Aug 16, 2012 7:37 pm |
| StoicBehavioR wrote: |
Ask them if it is a "B" stock. Even if it is, $1,399.99 is a good price since new would have been about $2,200.00. The fret popping isn't a bad thing. It's usually purely cosmetic. It means that there may have been some moisture under the clear and it didn't settle on the fret ends, or the fretboard may have shrunk slightly when it was settling. My custom shop Gibson has some fret popping and it's not even remotely bothersome. You won't be able to even feel it when you run your fingers over it. I would buy that guitar. |
StoicBehavioR
Fri Aug 17, 2012 5:29 am |
The guy says it's a 1-off custom. If that means anything. |
Fri Aug 17, 2012 6:46 am |
I don't doubt it. It's one off for sure, and US Masters made for sure and the markings on the rear of the headstock are real. I have had 2 USA Deans made with the same markings from around that time. New it would have been around $2200 without the fret popping. I can't tell if it was sold to the dealer with the fret popping as a discount B stock or if that happened afterwards. Either way I think the price is fair, so go for it. |
Fri Aug 17, 2012 10:17 am |
My B-stock USA Blueburst ML cost me $1200. |
_________________ DOA Member 01-00015
2011 USA ML Beveled edge |
Fri Aug 17, 2012 9:56 pm |
wstoll
Sat Aug 18, 2012 2:50 am |
| Grim Reaper wrote: |
| Carlino special order paint 1 off |
Nope....the earliest Custom Razor Backs Eddie did were 2007. |
81 USA Cadillac
82 Baby Z
02 25th Anv Caddy
05 P-90 Z
03 TC Caddy Custom
05 TC Exotic Z
06 TC Korina Z
All DOA Guitars
L.W. Sig #48
07 TC Korina Caddy
07 Soltero #22
07 TC Z
07 Lost 100 Z
08 Vinman 2K
09 USA Baby Z |
Sat Aug 18, 2012 5:04 pm |
I wouldn't buy dollars for 90 cents from Carlino! |
_________________ DOA 02 00012
(sez 1 vulture to another) |
Sun Aug 19, 2012 2:45 am |
| 60srocker wrote: |
+1. |
_________________ DOA Member # 06-00859 |
