Wed Oct 31, 2012 6:44 pm |
Wed Oct 31, 2012 7:34 pm |
It's hard to see what you're doing. The light coming through your window is washing things out. Try facing the light so you're not backlit. |
Wed Oct 31, 2012 10:04 pm |
Sorting lighting out. Made any difference? |
| Milje wrote: |
DOA# 09 02176 |
Wed Oct 31, 2012 10:39 pm |
| longhurstgb wrote: |
Did you change anything? Try filming while facing your window. It will use the outside light in your favor. It will make all the difference. That or maybe try a new location where you can control the lighting. Otherwise you'll be good. |
Wed Oct 31, 2012 11:30 pm |
I like them a lot. I've got two pairs and they've worked great so far. Was using Dunlops before that. Tried Schallers...wasn't really a fan. Also tried the Dimarzio Clip-Lok strap and didn't like that material for the strap. |
Thu Nov 01, 2012 11:14 am |
ive owned a bunch of different kinds and found the balls to wear out or washer screws to come unscrewed or they just fall apart or are just to damn bulky.now i unscrew the strap button slide a washer over the smaller end then the strap then screw it back to the guitar.this has never failed me and never comes apart.I got 3 stage guitars with 3 straps no problems at all.cost me a buck to do all 3 guitars  |
Thu Nov 01, 2012 2:31 pm |
"JODI" makes a Good Strap Lock , actually a few different ones...Same ones Dime used , Love mine , u just pull the lock up and slide it on the end of your guitar ends...So easy a "Caveman" could do it  |
_________________ Slimes , 95,01,05
Furman, 6Band, MXR Flang/Dub. |
