sarafdimebag
Thu Nov 01, 2012 5:36 pm |
I have Randall RH300 G3 amp and randall 300w Cab. How to connect these? amp has two outputs of 4oms, and cab has 2 inputs left says 4 omhs and right says 4 and 8 omhs. can i use regular guitar cable? Thanks |
Robo Cop
Thu Nov 01, 2012 5:54 pm |
| sarafdimebag wrote: |
The two outputs are connected in parallel. Anything you connect in total cannot go below the minimum ohm rating of the head (4 ohms).
Your cab can either be run in stereo (2 sets of speakers at 4 ohms EACH), or a single mono connection which internally connects your 2 sets of 4 ohm speakers in series for a total load of 8 ohms.
Connecting 2 cables to your head and cab will result in a 2 ohm load, and fry your head - DO NOT DO IT.
Connect a single SPEAKER cable (NEVER use an instrument cable to connect a head to a cab) from your head to the mono 8 ohm input of the cab. |
_________________ DOA 02-00027 |
sarafdimebag
Thu Nov 01, 2012 6:04 pm |
so i use one cable and insert it in no matter which output of the amp (left or right) and that goes on 8 omh input on cab? |
Robo Cop
Thu Nov 01, 2012 6:16 pm |
Correct - and remember to use a SPEAKER cable, NOT a regular instrument cable. |
sarafdimebag
Thu Nov 01, 2012 6:19 pm |
Robo Cop
Thu Nov 01, 2012 6:23 pm |
| Thanks a lot my friend! |
No problem, plug in and enjoy ! |
