 A question for the pickup wiring gurus... View next topic
PostPosted: Tue Nov 06, 2012 6:27 pm Reply with quoteBack to top
Pickup bleed.... I have noticed this on 4 or 5 other guitars I have owned including my new one. With super high gain pickups when you have 2 volume knobs and one is off, for example:
Neck volume is all the up and bridge volume is off and the pickup selector is on bridge, you can still get a little bleed through on your amp on the lead channel.
The reverse can be said for the neck pickup if the switch is on the neck pickup and the neck volume is off and the bridge pickup volume is turned on.
With both volumes off though it's completely silent.
I thought it may have been a wiring error, however they did a great job of wiring the guitar, but being a guy I am, I took it to my local tech who is AMAZING. I had him re-wire the guitar just in case... Same thing... He said it's likely because the pickups are so high gain that there is just bleed through. I called Seymour Duncan and they don't have an answer for me either.
The pickup cavity on the guitar is completely shielded as are the pickup cavities. The wiring is super clean and all wire lengths are cut to the exact lengths needed, there is no excess at all. One other thing my tech said it could be is the pots. He said if I changed from the mini pots that come with the Blackouts to standard size pots it could help...
Like I said before I have had this on a few other guitars and this is the second time I have seen it on a custom guitar. The last custom was a US Masters V. Is it the configuration? Is it faulty pickups? Is it gremlins? Is it just something that happens? I love the tone and it in no way takes away from the guitar itself and it turns off enough to not be a big deal. I just don't understand why it's happening.
PostPosted: Tue Nov 06, 2012 7:51 pm Reply with quoteBack to top
I have a Dillion V, that has been rewired numerous times to try and eliminate this problem. And for the record, the PU's are HOT AS HELL.
I've changed pots, switch, jack, wires, everything, and it is properly shielded.
I blame Gremlins.
PostPosted: Tue Nov 06, 2012 7:56 pm Reply with quoteBack to top
I blame Gremlins.
It's an odd phenomena huh?
Viper_Rising
PostPosted: Wed Nov 07, 2012 12:43 am Reply with quoteBack to top
I know you had Blackouts but I went on emg's website I hope this is helpful
"Sound bleed: swap the volume output and pup cable wires on the volume pots. This will get rid of the bleedthrough."
Sound bleeding it's one of the reasons I switched off from active pickups.
www.myspace.com/alexlopezrock
PostPosted: Wed Nov 07, 2012 1:14 am Reply with quoteBack to top
I like this defect..., and I have it on some of my guitars.
While playing live, I sometimes like to roll my vol down to "1" when I play my Fix'd Fuzz. With a slow phaser on, it sounds absolutely hypnotic. I love it!!! Very Happy
On guitars that go silent when I do this..., I have the potential to mute my guitar accidentally if I roll below the "1" on my volume. On my "good or defective" guitars..., depending how you look at it, it never happens Cool I use my Mark V mute button to silence my rig anyway.
PostPosted: Wed Nov 07, 2012 1:43 am Reply with quoteBack to top
The wiring on a guitar is a continuous circuit. The only way to defeat the bleed through is to have on/off switches inline with whatever pickups you're having the trouble with. The switch breaks the circuit.
PostPosted: Wed Nov 07, 2012 1:47 am Reply with quoteBack to top
For the record though, the last guitar I had which had this issue was with passives. So it's not that the pickups are faulty? This is normal and much more pronounced on certain setups? I will try and swap the tabs that the two wires are hooked up to and see what happens. If it doesn't totally fix it I'll just deal with it. It's not a big deal just want to fix it if I can.
PostPosted: Wed Nov 07, 2012 2:24 am Reply with quoteBack to top
That's what I was thinking might work. Flip the in and out connections on the potentiometer, and that might work. I believe that changed how it acts on the middle position on the selector switch though. On one of those, you roll down either volume and it controls the output volume, the other it controls just that pickup in the mix. If that doesn't change I have no idea. I've never noticed this issue so I don't have any experience with it!
PostPosted: Wed Nov 07, 2012 3:09 am Reply with quoteBack to top
Yes, in the middle one is volume and the other is mix. I actually prefer that too so switching the tabs may be against my best interest. Either way not a big deal.
PostPosted: Wed Nov 07, 2012 5:19 am Reply with quoteBack to top
you have a shitty pickup selector. i have had this a couple times on the stock switches. replaced them with a quality switch and phenom went away.
PostPosted: Wed Nov 07, 2012 5:33 am Reply with quoteBack to top
The switch is from Switchcraft. What do you suggest I replace it with? I'll order it if it's better.
PostPosted: Wed Nov 07, 2012 2:40 pm Reply with quoteBack to top
This should fix your problem. I hate when my guitars do this and that usually works for me. I have even gone to the lengths of running independant ground wires to each pot from the input jack to resolve problems of this nature.
PostPosted: Wed Nov 07, 2012 3:58 pm Reply with quoteBack to top
C&K 7000 series switches are the way to go. I've got one in my washburn stealth and they came standard. It's the only one i have and it's superior in feel and quality. I have swtichcraft too and they suffer the same problem as normal swtiches they are using the same design.
It's a fully sealed unit and they do military grade ones too Very Happy
MKK #:07
PostPosted: Wed Nov 07, 2012 6:52 pm Reply with quoteBack to top
OK Thanks I'll check it out.
So does this mean just swap the tabs on one pot or both? It will only take a minute to do it but I don't want to guess lol
PostPosted: Thu Nov 08, 2012 2:49 am Reply with quoteBack to top
Swapped the tabs on the pots and it's all fixed now! \m/
