 Does anyone know the part # for a Tone Pros locking Bridge View next topic
PostPosted: Sat Nov 17, 2012 9:04 pm Reply with quoteBack to top
... for a USA Dean TCZ? I'm so pissed!!! The bridge is actually cracked at the post... WTF?!
There are so many replacement pasrts and I want a direct replacement. Looks like it may be an T3BP ... but not sure.
Thanks
DOA #02 00039
Just one Guitar... slung way down low.
PostPosted: Sat Nov 17, 2012 10:02 pm Reply with quoteBack to top
Yes, a T3BP is the one you need.
Just a heads up on the pre-notched saddles though... they are only slightly pre-notched and will need to be filed a touch deeper/wider in order for the strings to seat properly. Easy job though, so no need to worry.
Les Paul Build #01:
http://www.deanguitars.com/forum/viewtopic.php?t=92515&sid=dce70906abd73e83b43e3f280c6870c3
LP Build #02:
http://www.deanguitars.com/forum/viewtopic.php?t=94430
DOA 07-01232
PostPosted: Sat Nov 17, 2012 10:04 pm Reply with quoteBack to top
Thanks for the confirmation... Wink
DOA #02 00039
PostPosted: Sun Nov 18, 2012 1:10 am Reply with quoteBack to top
Thanks
I would thnk that would be covered under some sort of warranty eh Chuck? Something like that happening on a USA is inexcusable, sounds like crap pot metal
PostPosted: Sun Nov 18, 2012 12:37 pm Reply with quoteBack to top
Thanks
You would think.... Cool
I'm just shocked at how it cracked all the way through. I've never seen anything like it. Like you said... cheap pot metal or a manufacturing defect.
This happens to be on a very early TC... going to check the markings on the bottom when I swap it out.
DOA #02 00039
