ATR1990
Mon Nov 19, 2012 8:26 pm |
Hello... Again Haha.
Ok, so I've been thinking for years about getting an Airbrish kit. Nothing Fancy, just something around the £100 ($150) mark... There's a whole bunch on eBay which look good for a beginner like me.
I'm not sure if any of you guys could browse on eBay uk at the airbrush kits, and tell me which is the better if the bunch.
I only ask, because to me, they all seem really good for a beginner. I was going to go with gravity fed, because my first project will be a DFH lighting paint job. (I can already use a spray gun, with facilities, to do the black on blue for the body, so the airbrushing will be done out in the back yard shed.)
The DFH will more than likely be a hardtail, I favour them over floyd's. I know there's someone here who did a hardtail DFH too, and it looked sweet.
Tips on how to set up the paint would be helpful, should I thin it out for the larger bolt behind the thinner inset one.
If all is a success, and I keep it up, taking on bigger tasks and all, I'm sure I'd need a better kit for that. But this will simply be for the lightning effect on the DFH.
Thank you all. |
GETCHA SOME ! |
Mon Nov 19, 2012 8:29 pm |
Why don't you see what you can buy, and get support for, at a local shop. It'd be a pain to buy something and find no one around can help you or get you parts. |
ATR1990
Mon Nov 19, 2012 8:49 pm |
In my town and surrounding areas there's nothing beside stores, main city things, fashion stores, supermarkets, music shops.
Luthiers, hobby stores are few and far between. Parts and paint would be bought online when I have to re-stock. That's the way it is now. My local guitar stores have all closed, moved further away into the Capitol.. Nearest guitar store is an hour away. |
GETCHA SOME ! |
Mon Nov 19, 2012 10:53 pm |
stick with one the name brands and parts will be available, i started with a badger 30 years ago and can still get parts ,
gravity feed helps use less paint a few drops at a time in bowl for lines
check bear air and airbrush depot as a couple online sites
look at a Peak C-5 got one from bearair for goodprice real good starter gravity feed |
_________________ DOA # 04-00298
down inside of me they still live on!!!! |
Thu Nov 22, 2012 7:05 pm |
I'm not an airbrush artist by far, but I do recommend the following which will make your life easier:
-2 gallon compressor
-2 water traps (over kill I know but if you were to lose one you still have on)
-Masking tape
-Research
-Sticking to gravity feed airbrushes
After that, if you can get a Master's airbrush (a good one runs about $40 US) you'd be pretty well set for starting off. |
_________________ DOA #07-01268
Thu Nov 22, 2012 7:41 pm |
You got one of those Games Workshop stores near you? The ones with the strange neckbeards who play with little plastic figures? They sell airbrushes, and there'll be somebody who can teach you to use it. They're always super-friendly too, I think they're just glad for the company.  |
ATR1990
Sat Nov 24, 2012 9:02 pm |
Jeepster and berserker thank you dudes.
also @what-a-cool-username i certainly do have one of them that just opened here. i'll check it out man. thank you. |
GETCHA SOME ! |
