 restoration View next topic
steve1961
PostPosted: Fri Nov 23, 2012 7:23 am Reply with quoteBack to top
Hi,i am currently restoring a Dean Evo guitar and need to replace one of the pots,my problem is im not sure which is the correct one to use any advice would be much appreciated and i thank you in anticipation of a reply
steve
Afe
PostPosted: Fri Nov 23, 2012 9:16 am Reply with quoteBack to top
You mean you are not sure which one is broken? If so:
1.set every pot at zero
2.increase one at a time and chceck with multimeter/voltage meter
if it passes voltage to the next pot.
Potentiometer increases the current resistance so if you set them at 0, the resistance is high enough to stop the current.
Wink
steve1961
PostPosted: Fri Nov 23, 2012 10:16 am Reply with quoteBack to top
Thank you Afe thats what i needed to know.. Very Happy
