Fri Dec 07, 2012 8:03 pm |
The '78 that I restored in my avatar... well this is the guitar I'd like to be my go to for my new band. Well turns out I've never played it over high volume before and it makes some ridiculous noises under high gain. I installed all electronics and wired everything on this.. so I know I screwed something up. I didn't shield any cavities or anything.. I'm hoping maybe that's the issue? How would I go about that?
And it makes very odd noises if that helps. Not feedback. More like crazy warbling and robot noises. I haven't been able to understand its language yet. |
_________________ 1979 Dean Z
DOA: 09-01874 |
Fri Dec 07, 2012 9:09 pm |
Fri Dec 07, 2012 10:27 pm |
Pickups too close to the strings? |
Fri Dec 07, 2012 10:58 pm |
| Graunke wrote: |
it sounds haunted.
Send it over to me right away so I can send it back to hell. |
It sounds like a shielding problemo to me, bro. |
Fri Dec 07, 2012 10:59 pm |
you have a photo of where all the leads are soldered?
Maybe it's just too much guitar for you and you should send it to me so I can teach it a lesson.  |
_________________ DOA 06-00934
Some Teles, a couple USA Deans, and Czech Z |
Fri Dec 07, 2012 11:18 pm |
I should record some clips of it before fixing it... it indeed sounds haunted.
and no, I wouldn't dare send it to any of you. I couldn't put you guys at the risk of being haunted. I care too much.
how would I shield it? i'll get some pics of the cavities. |
DOA: 09-01874 |
Fri Dec 07, 2012 11:34 pm |
These dudes are going to hook you up. Some very cool methods of shielding and making sure everything is grounded and soldered correctly |
Sat Dec 08, 2012 12:56 am |
As long as you use shielded wire you don't need cavity paint or sheilding tape. I use the vintage braided wire to wire the pots, switches and output jack. In addition to grounding the bridge and each pot to each other. I had to rewire my TCML and now it's Ninja quiet. |
Sat Dec 08, 2012 5:50 am |
When this happens, its the ground to the bridge 95% of the time from my personal experience. Or you didn't use shielded wire. Thats the best 2 guesses I have to get you started. |
Sat Dec 08, 2012 5:31 pm |
| koury73 wrote: |
I think I was just a retard when I did this... pics uploading. |
DOA: 09-01874 |
MZDA
Sat Dec 08, 2012 5:43 pm |
Maybe it's picking up some cell phone interference or something? |
_________________ DOA # 05-00617
WWDD |
Sat Dec 08, 2012 6:06 pm |
Ok so I see some bad things immediately. I made sure not to touch a thing so you guys can point everything out. First off.. it appears I used some type of old speaker wire or something to run to the toggle. I don't know how big of an issue that might be causing. I really can't re-do that. I had to drill holes through the body to basically re-route it to allow me to run wires through.. and its very tight and very difficult. I hope I can avoid re-doing that. Also the coil split wires the tape came off/exposed, that could be an issue.
Please point out anything you can. Like I said.. its actually dead quite at regular volumes. I never knew there was an issue til I cranked it to band level. And its not a feedback, it's crazy robot noises
DOA: 09-01874 |
Sat Dec 08, 2012 6:55 pm |
It's the grey unsheilded speaker wire. It's acting like an antanna. Get the vintage wire I mentioned. It's small enough that you won't need to redrill. Pm your email address and I'll send before and after pics of my TCMl for reference. |
Sat Dec 08, 2012 7:34 pm |
| '87 sherwood wrote: |
Is it interfering with itself or only outside noise? I would really prefer to find another way to go rather than re-wire. I've got enough to worry about getting ready for this show. Can I just shield the cavities? |
DOA: 09-01874 |
Sat Dec 08, 2012 8:01 pm |
Shielding the cavities might decrease it but it's not the best way. You'll still pick up radio interference along every one of those wires outside the cavities. For example, the long run to the selector switch. You'd be hard pressed to shield inside those drilled holes and runs. |
Sat Dec 08, 2012 8:05 pm |
what would I shield with? I've never done this before. I figure if it's easy to do I could at least try it quick. I've got a noise gate as well. |
DOA: 09-01874 |
Sat Dec 08, 2012 8:26 pm |
To be honest I could rewire that whole guitar with the braided wire a lot faster than I could shield paint it or copper tape it. I don't recommend sheilding the cavity. |
Halfaed
Sat Dec 08, 2012 8:49 pm |
Let me get this straight. Dude's telling you what is wrong and it's the easier fix, but you don't want to fix it the way he is telling you? What do you want him to do, come and fix it for you?
I love that old geet. It won't be fixed until you redo the wiring. I think you would be waisting your time if you did shielding everywhere. Good luck. |
_________________ DOA# 07-01264 |
MZDA
Sat Dec 08, 2012 8:56 pm |
| Halfaed wrote: |
srsly |
WWDD |
Sat Dec 08, 2012 8:58 pm |
I'm just honestly not sure if I can fit braided wire through there. Its hard to see but the wires are actually snug through the hole into the control cavity. I'll have to take a look to see what I can work with.
I didn't ask him to do it for me, lol. I asked if it would be worth trying to shield the cavities. I have never done it before and was unaware if it was a project or literally just putting something in the cavity. |
DOA: 09-01874 |
Sat Dec 08, 2012 9:23 pm |
I'm also still concerned that the wire used isn't the only issue. Most guitars don't have shielded wiring (other than the pickups), but do not get this noise that I'm picking up. I'm wondering if it could be something with the way I wired the kill switch, or possibly ground loop or other issue.
Anyone noticed anything in addition to the wire used? |
DOA: 09-01874 |
