nippyjun
Sun Dec 16, 2012 6:55 pm |
What stand do you use for razorbacks and ml's?
And is there any harm to using a stand that hangs the guitar by the neck. Can it damage the neck over time by having the entire weight of the guitar hanging?
Thanks. |
Sun Dec 16, 2012 7:07 pm |
Sun Dec 16, 2012 7:09 pm |
I use these
Sun Dec 16, 2012 7:10 pm |
nippyjun
Thanks.
Which hercules model works with a razorback.
There is one model the gs412b that has a little t-bar that extends out that looks like it would work. Is that the one? |
nippyjun
Sun Dec 16, 2012 7:11 pm |
Thanks.
nippyjun
Sun Dec 16, 2012 7:13 pm |
Bloodroot: that looks like the one I mentioned but for 3 guitars.
Do you happen to use a razorback or ml in there? Does the t-bar keep it off the legs of the stand? |
Sun Dec 16, 2012 7:29 pm |
| nippyjun wrote: |
I use an ML and a Stealth which is basically the same size in one of them and ESP LTD's in the other. so the vertical bar is adjustable to fit various size guitars. |
nippyjun
Sun Dec 16, 2012 7:33 pm |
Is the bar adjustable by moving up and down? |
Sun Dec 16, 2012 7:38 pm |
| nippyjun wrote: |
yea , you sqeeze the grip to slide it up and down then let go to secure it. there are little teeth that go into holse in the bar so it wont move when you let go of the grip to adjust it.
*Hercules tests for many types of nitro finish, however some guitar manufacturers change their nitro mixture often. Guitars should never be stored on a stand...always in the case.Auto Grab System yokes
Specially Formulated Foam
Hand Grip Height Adjuster
Adjustable backrests
Height: 35.6"-44.4" (905-1130mm)
Weight: 6.38 lbs. (2.9kg)
Base radius: 14.5" (370mm)
Load capacity: 66 lbs. (30kg)
Folded size: 29.9" x 5.3" (760 x 135mm)
http://www.ebay.com/sch/i.html?_odkw=hercules+stands&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=hercules+tri+stands&_sacat=0 |
nippyjun
Sun Dec 16, 2012 7:59 pm |
