 Can you fix the Reverb knob on a RT503?? View next topic
martynmordecai
PostPosted: Tue Dec 18, 2012 2:05 am Reply with quoteBack to top
I have an RT503 but the reverb knob dosent seem to work.
Any suggestions?
I Got Enough Beef To Put A Herd Of Cows To Shame.
PostPosted: Fri Dec 21, 2012 11:30 pm Reply with quoteBack to top
Honestly,
without diagnosing the problem with what exactly is at fault you're best off taking it to an amp tech. They should be able to find the cause and fix it for you.
MKK #:07
PostPosted: Fri Dec 21, 2012 11:51 pm Reply with quoteBack to top
youll need one of these.
when patience has run thin and youre all out of curse words. only one thing will suffice.
martynmordecai
PostPosted: Wed Jan 02, 2013 1:38 am Reply with quoteBack to top
i have finally fixed my reverb!!!
i routed the problem back to broken cable in the reberb tank on the head and soldered it back together.
The heads sound is much better now (never knew a faulty reverb tank could hinder the tone that much......or is it me?)
The only problem i have now is that i believe that the reverb is too soft/weak. Are there any mods i can do to the tank to improve this?
Thanks
PostPosted: Wed Jan 02, 2013 2:24 am Reply with quoteBack to top
Thanks
Get another reverb tank. Pretty much any size will fit in the head. The best reverb tank I ever heard was in a SUNN Beta Lead Combo
PostPosted: Wed Jan 02, 2013 2:33 am Reply with quoteBack to top
I'm not familiar w that amp but I do believe the reverb tank does effect the tone of the amp. Some say it's negligible but to me some amps sound more full w/o the tank.
PostPosted: Wed Jan 02, 2013 4:40 am Reply with quoteBack to top
I use very little reverb. I don't care for it much really.
