Thu Dec 27, 2012 2:25 am |
I'm waiting for Positive Grid to release Jam Up Pro for Mac which they told me is coming out soon... Peavey however has AmpKit which I got from the app store for my Mac a few days ago and it's really good. It's much better than the other stuff out there I have tried (Amplitube and Podfarm). Here is a screenshot I just took... It's got some really good amp models and pedals and the cabs/mics don't blow like the L6 stuff.
It's got a metronome, recording with re-amping and of course a tuner. Anyway, I know we have discussed this stuff in the past so I wanted to share that this is really good for practicing and getting ideas down. |
Thu Dec 27, 2012 12:35 pm |
How much is it, Lanning? |
turnstoashes
Thu Dec 27, 2012 12:52 pm |
its £34.99 in the UK |
_________________ DOA #06-00762
Dean FBD ML 2005 Edition
Jackson Performer Custom (own custom job)
ESP/LTD KH25
Epiphone Limited Edition Les Paul
Peavey 5150 MkII
Marshall Mode Four Cab
Dunlop Dime Crybaby Wah & Various Pedals |
Das Brutalheimmer
Thu Dec 27, 2012 1:05 pm |
Lanning, how are you plugging your guitar into your Mac? I'm trying to use it on my Macbook but can't seem to figure it out. |
Thu Dec 27, 2012 6:58 pm |
| Das Brutalheimmer wrote: |
I have iRig... It was $19.99 at the Apple Store. I think Best Buy has them too. It converts a guitar 1/4 plug to a signal for the headphone jack on the Mac and has a headphone out to run to headphones or speakers or whatever.
Make sure you adjust the I/O levels on the bottom of the screen to match your guitar's input so you're not clipping. |
Thu Dec 27, 2012 7:18 pm |
If you get a chance man, post up some clips. I'd love to hear it!! |
Thu Dec 27, 2012 7:49 pm |
For 10 bucks I might give this a try on my iPad. |
_________________ DOA member 08-01679
| I prefer to play Metal and Pinch Harmonics |
Das Brutalheimmer
Thu Dec 27, 2012 8:22 pm |
Hmm...I have Ampkit Link which should work the same way. I'll have to see if I have my port settings correct on the macbook. |
Fri Dec 28, 2012 8:52 pm |
I put it on my ipad. So far I like it but I am getting a lot of "feedback" if I have the gain turned up past like 3 if I don't use a gate. I have my input turned way down and it helped a little bit but not a lot. If I can fix that it will be cool. |
Fri Dec 28, 2012 9:01 pm |
| milje wrote: |
That's odd that you're having a problem. What interface are you using? Can you take a screenshot with the settings you're using so I can see what's happening? |
Fri Dec 28, 2012 9:49 pm |
How do I take a screenshot on an iPad? I had the issue with the stock settings on the Valveking that it started with, then switched to a 3120 with the same issue.
I'm using an irig. |
Fri Dec 28, 2012 10:24 pm |
OK I'm using iRig as well with none of those issues so I should be able to help you. To take a screenshot on your iPad click the power button and the home key button at the same time. Also if you PM me your email I can send you one of my patches and you can try it out to see if it's any better for you. |
