 Which modeler can get me the best goosed JCM 800? View next topic
RenegadeDave
PostPosted: Tue Jan 01, 2013 6:50 pm Reply with quoteBack to top
Can anyone record me a clip of some over the top power metal on a modeler? The HD 500 is appealing but I haven't found any good boosted clips on the tube so I know we have a few users here so I figured I would ask. Also, if we have any mustang 3 or 4 users, could you record a "British 80's" clip with boost via USB? I am looking for a new silent practice/ recording rig and am getting close to my sound on my XT live but would love to find a better model that reacts better and potentially without the high end fizz of the XT.
Any takers? Playing some Hammerfall , Dio, or Priest would be great.
Thanks!
"What are those, chairs?"
Ye Black Knight wrote:
RenegadeDave, truly thou rock at levels most advanced!
DOA #08-01509
PostPosted: Tue Jan 01, 2013 6:59 pm Reply with quoteBack to top
What kind of computer are you using? Do you have an iPad or iPhone? The best sounds I have heard for under 2k is AmpKit from Agile and JamUp Pro XT.... You'll need an iDevice for those though.
Other than that I would say the best is the Kemper modelling amp followed by the Axe Fx... The older Standard can be bought for a good price now that it's discontinued. I didn't like the one on the HD500 which I used a lot for about 6 months. I didn't like the model on the 11Rack either because it had some weird frequencies in it that couldn't be taken out.
If you have an iPhone, iPad or Mac though then you can get set up for pretty cheap and they sound amazing.
PostPosted: Tue Jan 01, 2013 8:03 pm Reply with quoteBack to top
kemper and axe fx. everything else has wierd mids and scratchy digital highs.
RenegadeDave
PostPosted: Tue Jan 01, 2013 9:33 pm Reply with quoteBack to top
I do have an iPad but would like something to stand alone as well.
DOA #08-01509
PostPosted: Tue Jan 01, 2013 9:39 pm Reply with quoteBack to top
BLOODROOT wrote:
...scratchy digital highs.
You can get a cream for that.
PostPosted: Tue Jan 01, 2013 10:32 pm Reply with quoteBack to top
If you have the iPad get JamUpPro XT... It's like an Axe Fx on iPad. It's amazing, and totally beyond most anything else out there. It's cheap because you already own the hardware...
http://www.youtube.com/watch?v=n196r771LF8
PostPosted: Fri Jan 04, 2013 2:42 am Reply with quoteBack to top
Totally juiced JCM800? I use the 5150 model on my Roland Cube...
DOA# 9 02164
PostPosted: Fri Jan 04, 2013 4:17 am Reply with quoteBack to top
The voicings are different. 800s are EL-34 based and the 5150 is 6L6. They are two very different sounding amps. The 5150 is far from a 800 clone, that is a misconception. The 5134 on the other hand is EL-34 based and sounds quite British. There is nothing I can do to my 6505 controls to make it sound like a 800
EDIT: I have owned a few 800s, they still sound like a Marshall boosted or not, far from the 5150/6505. There is a few clips on Youtube of modded/boosted 800s, they sound awesome
balsack
PostPosted: Fri Jan 04, 2013 7:18 am Reply with quoteBack to top
I have always enjoyed the Simulanalog series of plug-ins. http://www.simulanalog.org/
They are free!
I have run the tube screamer before the marshall....it is pretty nice.
Play with a cab simulator on top of this and alot o options open up.
Good luck!
Lost 100 ML #71
Lost 100 ML #96
TCZ 30/50
Czech Korina V - RIP
PostPosted: Fri Jan 04, 2013 7:46 am Reply with quoteBack to top
My 800 has 6550s... All of the older ones were 6550 based before they had EL34s.
PostPosted: Fri Jan 04, 2013 11:03 am Reply with quoteBack to top
^^^^^ I agree on that point but the 6550 tube has way more crunch and headroom which is why it stands head and shoulders above a 6L6. I suppose a loose comparison could be applied if your talking about 6550 vs EL-34 equipped Marshalls. I guess it's all in the ears when comparing the two
I can tell you for a fact that my 6505 does not sound like an 800. I never liked the 5150/6505 being called a poor man's Marshall because I can't relate the two. This is just my opinion
PostPosted: Fri Jan 04, 2013 4:25 pm Reply with quoteBack to top
I have owned a 5150 212, a 6505 212, a 6505+ 112, (2) 6505 heads and a 6505+ head. NONE of them have ever sounded like a JCM800 to me. I used to have a 50 watt JCM800 MKII and I currently own a 2203ZW JCM800 so I can speak on that (The ZW is just a 6550 based original JCM800 that was made before Marshall actually re-issued the JCM800 because Zakk wanted his sig amp to be based off of an original JCM800, not some new incarnation).
The original JCM800s and the JMP2203 which is the predecessor to the JCM800 had 6550s in N America because at the time there was a lower supply of EL34s for N America. That and the 6550 is a much more reliable tube and has more low end and higher clean headroom where as the EL-34 breaks up sooner. In the UK and other places they came with EL-34 so you will find versions with both tube sets out on the market, and both amps can be biased to take either tube with a little tech work and some value changes internally.
The 5150/6505 has more of a SLO100 kinda tone if anything but even then it's still it's own thing. When James designed the 5150 for Ed it wasn't to mimic the sound of his Marshalls. They started from scratch and made something completely different.
Back to the modeller thing though. If you don't want to use the iPad for JamUp Pro then I would suggest the Kemper if your pockets are deep enough. Also you can get an original Axe Fx Standard for about a grand now and an Ultra for about $1400. The Kemper, brand new though is cheaper then the Axe Fx II and to me sounds better. That said, for $20 you can get JamUp Pro and have amazing tone on the iPad, so it's kind of a no brainer.
PostPosted: Sat Jan 05, 2013 9:25 am Reply with quoteBack to top
just buy a marshall.I have a jmp-1 rack preamp and its got every marshall tone in it u could ever need I love mine I use an ada microcab with mine. kills any modeler ive heard.its got great attack and isnt muddy.But hey thats my opinion but i do know marshall tone very well.Why play something that trys to copy or reproduce the sound your looking for?It will always be second rate to the real thing!
gunslinger
PostPosted: Sat Jan 05, 2013 11:09 pm Reply with quoteBack to top
I can't recommend the Kemper enough... Best gear purchase I've made in YEARS. Absolutely LOVE mine.
The Baddest Guitar Builder on the Planet
http://www.rig-talk.com/forum/viewforum.php?f=15
Buy your tubes from the most metal chick on the net:
www.valvequeen.com
