martynmordecai
Tue Jan 15, 2013 6:31 pm |
Can someone please tell me how i can connect my Guitar Rig 5, M-Audio Fast Track Pro and my Amp altogether so i can use my amp as a sound output..
Thanks |
_________________ I Got Enough Beef To Put A Herd Of Cows To Shame. |
Tue Jan 15, 2013 6:40 pm |
Have you tried the Guitar Rig website/forums? I'm sure they'd be a lot more knowledgeable than we would. |
Tue Jan 15, 2013 7:41 pm |
You'd be better off using a bookshelf speaker systrem. Output from the Fast Track into the Stereo. |
martynmordecai
Tue Jan 15, 2013 8:23 pm |
cant i use all the effects on guitar rig, then just output them to my amp? |
Tue Jan 15, 2013 9:10 pm |
You can do that. Just output the fast track pro to yours amps input. |
Wed Jan 16, 2013 1:30 am |
| '87 sherwood wrote: |
Wouldn't you want to use the amp's effects loop return so you're not putting an amp model into an amp? If you don't it will really sound bad. Guitar Rig 5 is NOT made to run into an amp because it's got full amp modelling, but you can run it into the effects return to try and get a decent sound, but it won't be as good as full-range studio monitors or a PA. Just remember when you put it in your effects return that you need to turn the output on the computer way down or your amp will be blasting because you'll be disabling the amp's front controls this way. |
Wed Jan 16, 2013 1:34 am |
My response was assuming he just wants to use the effects. For example, he turns off all the amp and cab modeling and runs a chorus and phasor up front.
Honestly from what little info he offered I'm not sure what he's specifically trying to do. |
