Tue Jan 29, 2013 1:10 am |
Overloaded it like a moron , instead had it on the Low Input & Not High!!! Guessing that's what happened when you JAM too LOUD!
Do any companies or Techs Exist that do work on these things?
Thx for any INFO. |
_________________ Slimes , 95,01,05
Furman, 6Band, MXR Flang/Dub. |
Tue Jan 29, 2013 5:13 am |
Well I guess if you have problems with yours , Just PRAY, & then beat it lightly, like an old 50's Television & your Furman should work again! :lol
I'm just speechless, but HAPPY my RIG is up & Running again! |
wildnorth
Tue Jan 29, 2013 4:12 pm |
Tue Jan 29, 2013 5:17 pm |
| wildnorth wrote: |
My thoughts Exactly! just imagine me yelling "Please GOD", WOOOOOOORK DAAAAAAMITT, then beat the $HIT outta it, & Now by miracle it works Don't ask me ?
You ever need a repair tech , u there with the Big Ol' Ti Tays, I charge by how many times I beat your Furman  |
Tue Jan 29, 2013 6:04 pm |
| Zombie Apoc wrote: |
| wildnorth wrote: |
Do you have it in a position that will receive a lot of vibrations? You may have shook a tired joint loose in it and when you whacked it, you reconnected the connection again. Its happened to every combo amp I have owned. Eventually I had to go in and perform surgery on them (re solder jointsn and replace electrics that just shook apart). |
Tue Jan 29, 2013 6:33 pm |
I had to of knocked something in the right place, all I know is I ordered another one right before I fixed it & now I have 2 , Geez, oh well! It is what it is, that's wild tho.  |
wildnorth
Tue Jan 29, 2013 8:21 pm |
I would think it's either a cold solder joint (easily fixable, just hit every solder point with the tip of a solder gun (using heat sinks where appropriate), or something was touching ground where it shouldn't have, and smacking the unit jarred it clear.
Either way, it's possible that as soon as you move the unit around the problem will re-surface.
Ordering a new one wasn't such a bad idea. |
Tue Jan 29, 2013 9:23 pm |
Thanks for TIT, I mean TIP, damn keep staring at those Massive Milk Bladders ...Man I hope she keeps on keepin' on , cuz even tho it's just a Furman , this one is clean and the other one look like it came out of JUAREZ , MEXICO....& NO RACIAL OFFENSE, I'm Hispanic so I can make that Joke MEH!  |
