 Double action truss rod? View next topic
PostPosted: Wed Feb 06, 2013 12:55 am Reply with quoteBack to top
Do Dean guitars have double action truss rods? I just adjusted the neck on my CFH and it felt like it was tight both ways, not the usual tighten to the right and just go slack to the left.
I had no problems adjusting it, I just thought that was kinda cool.
PostPosted: Wed Feb 06, 2013 1:32 am Reply with quoteBack to top
Yep. Most all the allen wrench type rods are 2 way. Turning to the right will pull the neck back, to the left will push it forward. Of course there will be a point in between where it is completely loose in the neck. I had a 79 ML that the neck played perfect with the rod completely loose with no tension either way, just kept it slightly snug to hold the neck straight.
Randall Century 200
Rg80ES-XP
Ceriatone Chupacabra
JCM 800
