Tue Feb 12, 2013 4:56 am |
K so my question is i want to change the power tubes in my dsl 100 Marshall.theres 4 el 34 power tubes.my question is this.I only use the clean channel on the amp.do i need to change all 4 output tubes or are 2 tubes for one channel and 2 for the other?or does the amp just run all 4 at once to power? |
Tue Feb 12, 2013 4:58 am |
It runs all power tubes at once. The preamp tubes are the ones that might be some for the clean, some for the distortion, this one for effects loop, this one phase inverter, etc, but the power tubes are always working. |
Tue Feb 12, 2013 7:17 pm |
thxs  |
Tue Feb 12, 2013 11:31 pm |
you also have to change them as a quad matching set and set the bias. there's a whole set up to go threw. cab plugged in to head ect |
Thu Feb 14, 2013 10:31 am |
| RobBouchardDeanml wrote: |
The way your asking it, I'd answer did it have a half power switch? That's the way only 2 or 4 tubes would be used. But yes change all the tubes. |
_________________ DOA Member 01-00015
2011 USA ML Beveled edge |
Thu Feb 14, 2013 9:39 pm |
i am and my buddy will bias it for me |
