Wed Feb 20, 2013 4:28 pm |
So was on a hunt for a kerry king but then was told to check out a quick rod. Seems they kick some ass and sound like a hot rodded jcm 800. Any one have one? May be more up my road |
_________________ Mesa mark 4
Framus Dragon
Triamp mk2
Engl Savage 120
Framus Cobra
Mesa Triple rec
Randall RG100es
Marshall 2203kk jcm800
Engl fireball 100 |
Wed Feb 20, 2013 5:41 pm |
Splawn Nitro-best sounding and brutal amp they make. It's next on my list for sure. |
Wed Feb 20, 2013 6:13 pm |
Splawns are pretty ballsy. some of the best Marshalls Marshall never made.
i have a supercomp i bought off some guy about a year ago. it's sick, although to be fair it was modified by FJA. here's a video of it just after beiong modified.
http://www.youtube.com/watch?v=ZX6o77C7w10
nasty friggin amp.  |
_________________ DOA 06-00771 |
Wed Feb 20, 2013 6:21 pm |
| koury73 wrote: |
. On the same page brotha |
Framus Dragon
Triamp mk2
Engl Savage 120
Framus Cobra
Mesa Triple rec
Randall RG100es
Engl fireball 100 |
I'm endorse Splawn now. If you have any questions PM me and I'll give you the deets. The only one I don't have familiarity with is the newer 22 watt. |
Thu Feb 21, 2013 12:35 am |
yea
quickrod is great for the juiced suped up marshall tone.probably the best solo tone out there right now.
nitro is great for the metal tone.
Im personally selling both my engls to get a bogner uberschall twin jet though. I thought about the fractal real hard but I couldnt respect myself without using tubes. |
_________________ this thread is like an ugly stripper. you know you're going to be disappointed, but you look anyway. |
Thu Feb 21, 2013 12:43 am |
So someone school me.A quick rod is a souped up Marshall tone.So do you still need an overdrive to boost it like on my JCM800 or is it plug and go brutlzzz?2 channel? |
_________________ DOA#06-00983
5150 Block Letter |
Thu Feb 21, 2013 1:06 am |
| Eternal Scar wrote: |
plug in and wicked broots.
it has 3 "stages" of gain (called "gears") you select between, so kinda like plexi, to 800, to ballsed up 800.
the quickrod is 2 channel
the Supercomp i have is just the single broots channels from the Nitro mentioned above. |
Thu Feb 21, 2013 1:10 am |
the quickrod is the marshall jose mod with splawns tweek which is better. Splawn, cameron and fryette all worked for jose arrendondo at one time is what I heard. I dont know if it is true. |
Thu Feb 21, 2013 2:19 am |
trying to hunt a used one down for around 900 or so. Guy had one in york pa but said it had a tube problem and he removed two tubes . as soon as i here HAD a problem with tubes im all set ... |
Framus Dragon
Triamp mk2
Engl Savage 120
Framus Cobra
Mesa Triple rec
Randall RG100es
Engl fireball 100 |
Thu Feb 21, 2013 9:29 am |
| BLOODROOT wrote: |
I talked to my rep at NAMM about this. He said Scott never worked for Jose and that the circuit is it's own thing. Just to add some light to the question. How close it is to the actual Jose mod though? I dunno. |
hellboundinFTworthTX
Fri Feb 22, 2013 1:14 am |
| BLOODROOT wrote: |
Plate fed tone stack and cathode follower eliminated and used as extra gain stage are a couple things that make a splawn a splawn. Jose's mods used clipping diodes to add gain, LOTS of it if wanted. Both are good, but Splawns retain more of a "Marshally" grind to me. Diodes smooth out and saturate the tone more easily, like my Chupacabra. |
_________________ Randall Century 200
Rg80ES-XP
Ceriatone Chupacabra
JCM 800 |
Fri Feb 22, 2013 2:11 am |
I may have to just buy a new one Im after one that looks like a plexi . black with gold trim and face.. having trouble finding one used . |
Framus Dragon
Triamp mk2
Engl Savage 120
Framus Cobra
Mesa Triple rec
Randall RG100es
Engl fireball 100 |
Fri Feb 22, 2013 2:13 am |
| hellboundinFTworthTX wrote: |
| BLOODROOT wrote: |
A Chupacabra was that animal on the land of the lost with will ferral !! haaaa |
Framus Dragon
Triamp mk2
Engl Savage 120
Framus Cobra
Mesa Triple rec
Randall RG100es
Engl fireball 100 |
Fri Feb 22, 2013 4:22 am |
| BLOODROOT wrote: |
Hmmm good to know. I read it at another big name amp builders forum from the amp builders posts. thanks for clarifying. Wonder why it was said. I'm just gonna stop reading s#%t on the interwebz. |
Fri Feb 22, 2013 7:52 am |
Yeah I wanted to know too because of all the cool "modded" Marshall amps that have popped up over the years. I was talking to Dal from Splawn and I said "so when did Scott work with with Jose?". Dal replied that Scott didn't know Jose more than just from maybe bumping shoulders at trade shows or if they had mutual clients. He said Scott has never worked with or for Jose. I kinda drew a blank after that and we changed the subject. I dunno why that other amp builder said that. |
Sat Feb 23, 2013 1:07 am |
Scott is a great amp builder.... I've been through a bunch of Marshalls trying to capture a certain tone I was chasing and settled on this Splawn 50 watt Competition. Excellent build quality and supreme selection of parts etc. you simply can't go wrong with one
_________________ DOA #02 00039
Just one Guitar... slung way down low. |
Sat Feb 23, 2013 2:45 am |
splawns are great amps, i bought my first splawn in 2006 and have owned a couple quickrods,promod, competition and a couple nitros. never had a problem with any of them, i played the competition live and it sounded great with a band mix. they are well built amps for the money and alot of choices in how you want it to look. scott is easy to deal with and i think hes a good guy. you dont need any pedals to boost like you do with a 2203, all of the splawns have plenty of low end and gain.
if there was a weakness in the splawn line it would have to be the clean channel, over the years its gotten better but the early versions had alot of early breakup and was nothing special. its a great amp for solos and lead work but its unforgiving and if you suck it wont cover it up. they are tighter feeling than a marshall and are very clear sounding in the gain. |
_________________ link to my guitars and amps:
http://s47.photobucket.com/albums/f183/XDISCIPLEX/ |
Sat Feb 23, 2013 10:19 am |
One tip I got from them is do not buy one with KT88s. They won't warranty those tubes because they have been very unreliable. Now I don't know this from personal experience with them but I originally ordered my Nitro with KT88 and they talked me out of it for the reason I explained above. I have EL34B in mine. |
Sat Feb 23, 2013 5:47 pm |
im not sure about the warranty issues but i had a nitro with tungsol el34 and another with kt88 and i liked the kt88 nitro the best, just depends on what ya like but i played my kt88 live and used it for over a year and never had a issue, i really like how the 88 sounded with the nitro. |
Sat Feb 23, 2013 6:22 pm |
| Les-Zombie wrote: |
Yeah the 88s sound better but Scott won't replace them under warranty if they blow within 90s days (or whatever the time period is) like he will with the EL34s. They said they have been getting complaints about the 88s not lasting from clients. |
